Cable routing
Calnago
by Calnago
Much better... looks good!
Still not a fan of any of those "linked" cable systems over standard cable housing, but that's a seaparate issue from the routing itself.
kgibbo1868
by kgibbo1868
Calnago wrote:Much better... looks good!
Is it the looks or the function your not keen on? They seem well made and very low friction to me. Looks are in the eye of the beholder indeed!
Pain is my friend!
Calnago
by Calnago
Yes, more the looks and they often end up looking kind of “kinky” to me. Plus, the joins become dust and dirt collectors. I’m sure they function just fine.
alcatraz
by alcatraz
Aren't they marketed as being lighter and compressionless?
Compressionless might be true but lighter I don't believe. There are some crazy light kevlar housing out there that is cheap and works ok. 26/20 gr/m brake/shifting w. alloy strands.
/a
commendatore
by commendatore
Calnago wrote: Still not a fan of any of those "linked" cable systems over standard cable housing, but that's a seaparate issue from the routing itself.
I’ve always been afraid of damage they might do to the headtube if the bars get wrapped around in a crash
Calnago
by Calnago
Well, they certainly could I suppose. But in the event of a crash that’s probably way down the list of what can go wrong.
But they will never keep a nice smooth arc shape like you can get from a standard set of nice smooth regular old cable housing. Campy or Shimano. And use of liners where appropriate, like around BB shells etc.
kgibbo1868
by kgibbo1868
I should have put them on the scale.....dohhhhh! They felt much lighter than the stock sram cables that came off, but compared to other lightweight aftermarket cables I really don’t know how they compare.
I’m not overly worried about dirt or dust as the slick inner liner will keep everything clean. It will most likely take a bit more effort to keep it looking clean though with all the groves between the links.
Pain is my friend!
Calnago
by Calnago
Yes, the liners keep the actual cable runs clean. And being black, the dirt won’t show too badly. But some of the bling light colored anodized links are more likely to be looking not so great in not so long a time.
mpulsiv
by mpulsiv
Are there any frames besides Scott with clean routing through the headtube on both sides?
alcatraz
by alcatraz
mpulsiv wrote:
Mon Nov 05, 2018 4:34 am
I like the design of this green frame. Allows for really neat and tidy cable routing.
It does seem like they dropped spacers or went too generous with the housing lengths. I reckon you could keep all the housing in front of the head tube if done well. No need for such long arches.
Come to think of it they might be running a crazy long stem. That would also result in a lot of excess housing.
In any case. That frame deserves a neater routing of cables than it got in the picture. :)
GothicCastle
by GothicCastle
RussellS wrote:
Thu Mar 08, 2018 12:47 am
I do not like switching the derailleur cables from side to side, as was done in this picture. The rear shifter cable is on the drive side, so it should only run on the drive side. In the picture it goes to the non drive side and then crosses the front derailleur cable to get the back to the drive side under the bottom bracket. No thanks.
This really depends on how the cables enter (or don’t enter) the downtube. For mechanical shifting, the goal is the least friction (most gradual bends) possible without excessive cable. Crossing in (or under) the downtube is perfectly fine.
On my Parlee, running the housing as you suggest introduces an extra kink in the cable that hurts rear shift smoothness.
GothicCastle
by GothicCastle
Calnago wrote:
Sun Mar 11, 2018 1:28 am
This. And when they collect dirt, they can start making noise. Not the end of the world, but another thing you might have to periodically clean.
mpulsiv
by mpulsiv
alcatraz wrote:
Tue Nov 06, 2018 8:17 am
Spacers and housing length is very much irrelevant. I like the fact that it's cleaner through the headtube, less cable and more aero. I think it's a better choice than to run cables through toptube (e.g. frame xyz) and downtube (e.g. frame xyz).
