Enve fork blackout decals
glepore
by glepore
Anyone holding or have a source?
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
RyanH
by RyanH
Jeff Kokies used to be the only source but Enve told him to stop. I believe Firefly will sell them for about $30 a set.
billspreston
by billspreston
I could make you the vector artwork for a vinyl cutter if you have a pair of calipers and can measure the logo dimensions exactly. I assume the overlay decal needs to be just slightly bigger to hide the white logo with some tolerance. Then it should be pretty cheap and easy to get some decals cut.
glepore
by glepore
Bill-thanks, will try this.
glepore
by glepore
Bill-thanks for the offer-I get 30 x 140mm for the ENVE and 16.5 x 26.6 for the small Road 2.0.
I had to measure the length of the enve with a tape as my calipers didn't reach, but I'm confident. If you can do the vectors I'll get a small batch printed for our own use.
kokies
by kokies
I am still doing these as custom orders. You can message me here or on paceline under the same user name.
kode54
by kode54
had i known, i would have had a set made since i couldn't find them on eBay anymore.
i ended up spray painting them with a hobby rattlecan, matte black. cleaned surface with alcohol, then lightly laid down a few thin coats until the desired black out. i didn't even take the tire off, LOL. you can't even see where the large white Enve logo was.
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 7.8 carbon hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 4.5AR CK CL hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
