Help me find a modern *steel* road frame
AlexMeeshell
by AlexMeeshell
ALAN Carbon+ wrote:
Thu Mar 01, 2018 10:28 am
I went through the same search about 18 months ago and ended up with Genesis Volare 931, which is also available with Reynolds 853.
Otherwise Condor Acciaio/Super Acciaio or Dedacciai Strada Zero 25 are worth considering assuming the geometry works for you.
Sent from my ONEPLUS A5000 using Tapatalk
Thanks for the lead. Had not heard of them before.
Mind posting a pic of the build?
XCProMD
by XCProMD
Pota!
https://www.ciocc.it/
Check the ProRace.
Don’t know if you’re located in the UK. If so just contact them, fly to Bergamo (Ryanair) or Milan, they’re a stone throw away.
Tell them what you want, they’ll make it in 6 weeks.
Inviato dal mio iPhone utilizzando Tapatalk
Roel W
by Roel W
What size is the Road Logic in this picture Marin?
CANYON Ultimate AL 2010
CANYON Ultimate CF SL 2014
CANYON Ultimate CF SL disc 2018
Instagram @roeleur
ALAN Carbon+
by ALAN Carbon+
As requested Image
Broady
by Broady
Gosforth 931 - https://gosforth.cc/store/gosforth-reynolds-931
Bargain, looks a peach too.
cassard
by cassard
Marinoni is Canadian, From Quebec.
No euro
Marin
by Marin
Roel W wrote:
Thu Mar 01, 2018 4:29 pm
IIRC my Logic it was a 55.
Mid-reach brakes can look ok too, I'm running TRP 957 on the Heretic CL2:
Note the clearance - 35mm tires fit just fine :D
Re Etap on the Ritchey: You can always cut off the cable stops and then just go to spot repair shop, they can probably match any paint.
AlexMeeshell
by AlexMeeshell
Marin wrote:
Fri Mar 02, 2018 2:02 pm
That's hot!
dolophonic
by dolophonic
Look around there are some great options .Image
I will be building this frame asap ! old school but they are still making frames Duarte from Colombia.
Hunter makes some great frames from Santa Cruz..
BOB78
by BOB78
I have no experience of the brand but it was on my list when I was looking for a new bike. The new version ticks a few of your boxes.
https://standertbicycles.exposure.co/triebwerk-mach3
dfischer1
by dfischer1
+1 on Stelbel SB/03
I had a Ritchey Road Logic. It's a nice bike, but I wouldn't call it "modern steel". Stelbel is leaps and bounds beyond.
MayhemSWE
by MayhemSWE
AlexMeeshell wrote:
Thu Mar 01, 2018 3:34 am
Had not considered Stinner.
Will check them out.
Thanks!
My Stinner Gibraltar frame was about 1600 g. Weight for custom geometry somewhere around a size 54/medium but slightly more relaxed and traditional horizontal toptube, internal brake cable routing with full housing guide and pressed in headset cups (but not the bearings).
Edit: Weight was obviously for the frame only and not complete frameset which accidentally stated originally. Sorry if I got anyone's hopes up!
AlexMeeshell
by AlexMeeshell
MayhemSWE wrote:
Tue Mar 06, 2018 4:52 pm
Thanks!
My Stinner Gibraltar frameset was about 1600 g. Weight for custom geometry somewhere around a size 54/medium but slightly more relaxed and traditional horizontal toptube, internal brake cable routing with full housing guide and pressed in headset cups (but not the bearings).
Cool.
Mind posting a pic?
waltthizzney
by waltthizzney
this bike is an insane deal, i heard it rides great and i think it can take 30mm tires, anyone have one? i want to get it repainted
https://www.planetx.co.uk/i/q/FRHOCO/ho ... n-frameset
