Giant Propel Brake (TRP TTV) Arms
JayUK
by JayUK
Hi all,
Two friends of mine have Giant Propel bikes, one is new, the other is a 2016 (I think). They both have the aero V brakes (TRP TTV model).
With the new bike, the brake arm where the brake cable enters first (where the noodle fits) has two holes (obviously one of the holes is in use for this task). But what is the other hole right next to it for? All I can think is that it allows you to quickly change the width/spacing of the V brake setup (spaces the noodle further out - hence closes the gap between the pads).
The friend with the old Propel, his V-brake arm only has the one hole.
If you look very closely at the attached picture, you can see the brake cable/noodle is using the back hole, there is another hole a few mm in front.
Many thanks,
J.
jlok
by jlok
JayUK wrote:Hi all,
Many thanks,
J.
Yes you are correct. They enable quick change between two cable pull lengths.
Sent from my SM-N9500 using Tapatalk
JayUK
by JayUK
Hi there,
Thanks for confirming :)
J.
sharkman
by sharkman
The brake in the picture is from fouriers (small investment to get to ultegra levell performance)
The second hole is helpful if a rim is bend and you still want to get home (without disabeling the brake)
Verzonden vanaf mijn iPhone met Tapatalk
IrrelevantD
by IrrelevantD
I had a 2015 Propel that came with the TRP brakes (I still have them if anyone wants them). In addition to what @sharkman said about the Fouriers.... it also allows you to run 25c tires in the back.
With the TRP brakes, you *might* be able to get a 25 to fit if it runs small. I got one that would spin, but there was about a 1mm hop in the wheel that would rub on the brake cable. With the Fouriers a 25c will clear no problem.
jlok
by jlok
Got this 2nd hand Propel Advanced. I think it's 2016. The rear brake cable clearance is abundance for Vittoria Corsa 25c tubular.Image
