I just bought a CAAD12 black inc frameset and I'm looking at my options for the crankset. The current plan is to use a Rotor 3D+ crank with the 30mm spindle, a power2max PM and a C-Bear bottom bracket.
I'm still not 100% sure if the Rotor crank fits the frame and if it's the right BB and before buying all the parts, I'd rather have a confirmation. (this is the crank)
BB fits BB30A and accept 30mm spindle: https://www.c-bear.com/en/products/cann ... hollowgram
I'm not sure if there are other alternatives for the BB but I'm looking for a BB with a housing to avoid the creaking. I'm not sure if Kogel has an equivalent...I could only find ones that accept 24mm spindle.
CAAD12 black inc x power2max question
Pretty sure this will fit. You will just have to work out which spacers you need. I'm planning on using my rotor 3df (also 30mm spindle) with my caad 12.
Not sure about the bottom bracket though. I would think just regular press in bb30 bearings will be the way to go.
Thanks! C-Bear confirmed that it's the right BB to use Kogel confirmed they don't have a BB30A BB that accept 30mm spindle (nothing in development). I wanted to go with C-Bear to prevent any creaking. I had a CAAD10 2 years ago and the Cannondale BB was creaking badly...srshaw wrote: ↑Fri Feb 16, 2018 11:07 pmPretty sure this will fit. You will just have to work out which spacers you need. I'm planning on using my rotor 3df (also 30mm spindle) with my caad 12.
- Similar Topics
- Replies
- Views
- Last post
- 8 Replies
- 327 Views
Last post by MisterMuncher
Thu Aug 02, 2018 2:18 pm
- 9 Replies
- 859 Views
Last post by TonyM
Sat Apr 21, 2018 1:07 am
- 6 Replies
- 455 Views
Last post by glam2deaf
Sun Nov 11, 2018 9:10 am
- 11 Replies
- 1083 Views
Last post by mythical
Mon Dec 03, 2018 3:38 pm
- 7 Replies
- 516 Views
Last post by mp123
Sun Jul 29, 2018 10:38 am
