Garmin GSC 10 just quit
mdeth1313
by mdeth1313
So my garmin speed/cadence combo sensor just quit on my winter bike. Never had an issue w/ the one of my WW bike but after multiple rides on the salted/treated/wet/sloppy roads, mine stopped working. Replaced the battery and it worked for one ride in the wet and now it shows it's picking up both speed & cadence magnets, but my head unit (garmin 800) won't pick it up. It will pick up the one on my WW bike so I'm figuring it's the sensor.
In the meantime, I had an old niterider cadence sensor so I'll use GPS for speed, but I really hate seeing my speed drop when I ride under trees or some other GPS obstruction.
I do have the option of using the cadence sensor with a separate speed sensor -
any recommendations?
Speedplay is the devil!
Juanmoretime
Administrator
by Juanmoretime
I’ve gone thru a few GSC 10’s, they seem like the Garmin heart rate strap and die after a while. I can get by with GPS on the road since where I live I never loose signal. When on the rollers I use the new Garmin sensors which do the job, Also went to a Wahoo Kickr for a heart rate monitor strap since I have gone thru too many garmin straps and sensors.
RESIDENT GRUMPY OLD MAN.
sungod
by sungod
i used gsc10 for many years on my commute bike with no issues
stuff fails, i don't think there's anything particularly unreliable about it, ugly as hell though
on my other bike the pm gives cadence anyway, i had a fork mounted one but switched to the garmin speed sensor that straps on the hub, couple of years all weathers, no issues so far, long battery life
this one...
https://www.sigmasports.com/item/Garmin ... unted/3L2E
mdeth1313
by mdeth1313
Thanks- I have a cheap speed/cadence sensor coming for now. I was looking to see if anyone is using something on a bike sees lots of (nasty) road spray. Over the years I've had a few gsc 10's quit after riding in the wet.
Interesting thing about garmin's chest strap for the HRM - I've had mine since my garmin edge 305 - I've had to change the battery a few times but I won't switch because it keeps working flawlessly.
sungod
by sungod
i do wonder if garmin's quality is consistent, my gsc-10 had maybe 8 years of year round commutes, and the uk isn't a dry country!
but i have the same experience as you with the hrm (model hrm-1b i think), mine is coming up for 9 years now, yet i see other people saying theirs failed quickly
