What Handlebars For True Weight Weenie Fashion(Rca build)?
tabl10s
by tabl10s
The THM Tibula I just purchased needs a fatter bar than the AX Lightness I have(bar is 146g and stem is 72g...both for sale...cheap). The AX combo comes to 218g while the top S-Works non-aero offering clocks in at 250g.
2016 Orbea Orca OMR:
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
2015 Pinarello F8(build in-process).
NiFTY
by NiFTY
Ok. Not clear at all. But i assume you mean thm tibia. I also assume you mean that the bar and stem were 26mm clamp not 31.8. In that case options for a light bar are the obvious schmolke tlo, with less common options bikeahead or haero h145sl in the 145-155g gram range. But it depends on the geo that you want. I have the haero h145sl. They are 155g in a 42cm bar. They are plenty stiff for me and the curve works for my hands.
Wookski
by Wookski
Schmolke TLO- the weightweenie handlebar of choice
trimenc
by trimenc
I agree, and own the Schmolke TLO and can confirm it is a great bar and uber light. My second choice would be the Haero h145sl.
tabl10s
by tabl10s
NiFTY wrote: ↑
Thu Feb 15, 2018 5:29 am
The bar measured to 27+. I'll check out the recommendations.
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
wheelsONfire
by wheelsONfire
Bikes:
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
RocketRacing
by RocketRacing
Darimo for me also, but it is not yet in my hands, but so far do good with their products.
wheelsONfire
by wheelsONfire
The THM bar has same shape as 3T Superergo.
Haero has the shortest reach, but sadly none of them has a drop of 125mm.
Anyone seen a bar with 75mm reach, 125mm drop?
Only bar i see with a shape and measurement i like, is Lightweight KompaktbĂĽgel.
But it's way to expensive (and rather heavy at 196g) for being made in Asia.
Bikes:
Ex bike; Vial EVO D
