Garmin face plate mounts?
PLuKE
by PLuKE
Hi
I currently have a Deda Superleggero stem, and I am after a Garmin 1000 mount that bolts onto the stem face plate.
I have a K Edge at the moment, but fancy a change. Can anyone point me in a direct?
Thanks
PLuKE
by PLuKE
bremerradkurier wrote:
Wed Feb 14, 2018 9:21 pm
Something like this?
https://www.aliexpress.com/item/3-in-1- ... autifyAB=0
Thanks, That has a slot to accommodate bolt hole width. But, I am not sure thats really that safe? and being off Aliexpress.
Maybe I need to measure the bolt width, and see whats out there.
bremerradkurier
by bremerradkurier
PLuKE wrote:
Wed Feb 14, 2018 9:25 pm
The mount itself is aluminum-a pair of known quality stainless bolts wouldn't be all that much.
ManekiNico
by ManekiNico
Fetha makes a mount with a 17 mm bolt pitch, which should fit if I'm measuring right. Strangely, they skip 18 mm and offer 19 to 35 mm pitches in 1 mm increments.
https://www.fetha.com.au/product-page/a ... late-mount
Edited to add: Knew I was forgetting someone… Edge-Mount also makes a 17 mm mount.
http://edge-mount.bike/?product=mount-17
There's a whole thread about them here: viewtopic.php?f=3&t=28122.
Mom: He was very sickly until he started riding around on that bicycle.
Dad: Yeah... well... now his body’s fine, but his mind is gone.
TheDoctor
by TheDoctor
I used this Fouriers mount for quite a while, worked well for me:
https://m.aliexpress.com/item/32429279430.html
Scott Addict Premium Disc
Specialized Tarmac SL4 Pro
Canyon Exceed CF SLX 8.0
Specialized Epic Comp
Wookski
by Wookski
In feather you’re limited to the adjustable mounts unless you have a 3T stem. The adjustable mounts suck.
Try carbonworks or alptitude- both carbon and light.
Wookski
by Wookski
TheDoctor wrote:
Wed Feb 14, 2018 10:16 pm
Man that is one ugly ass mount
r33prman
by r33prman
I have a featha on my deda zero100 -8 with a wahoo bolt. Best out front Mount Ever!
DT
NiFTY
by NiFTY
The fetha is great.
PLuKE
by PLuKE
Thanks.
I think the best thing is to measure the bolt width, and see what mounts would then fit my Garmin 1000 and the Deda stem.
I would rather have a fixed bolt mount, the adjustable bolt width look kind of unsafe?
Luke
