Ill fitting 1 3/8 bearing - are there different types?
ave
by ave
It's a chinese noname frame.
Somehow I don't think it's the correct bearing for this fork. It won't go further down even with torqued down headset.
The bearing should sit almost on the flat surface, no?
It leaves an unsightly gap when installed into the frame.
I do not know bearings. I measured this 37mm inside, 49mm outside, 7mm tall.
Are there different types with these main dimensions? I don't know anything about the angles.
I am hoping to somebody knowledgeable can help me with finding a solution?
As an alternative solution can sanding/grinding down the carbon bearing race a bit work?
wheelbuilder
by wheelbuilder
Yes. The bearing should be sitting down on that angled carbon race. Are you sure you are not putting the upper bearing on the fork by mistake? Is it a tapered fork? The chinese carbon frames sometimes have pretty severe tolerance issues.
ave
by ave
It's a tapered fork, yes. The bottom bearing is much bigger than the top one, so it's surely the "right" one.
I'll try to find a tapered fork in a bike shop somewhere to check where the bearing sits on that, but 1 3/8 is not too common size.
alcatraz
by alcatraz
Maybe you need a bearing with an appropriate chamfer on the inner race.
Like in this picture.
/a
ave
by ave
Of course it's chamfered. But what I'm wondering, maybe there are differently chamfered bearings with the same inside diameter of 37mm.
alcatraz
by alcatraz
There are different angles on the chamfer. Probably it won't help you.
Maybe riding the frame for a short while will seat the bearing. (assuming the frame is new)
/a
ave
by ave
The best picture I could manage showing the gap between the molded race and the bearing.
ave
by ave
Yes, I will try to ride it, to see if hitting potholes help. :)
alcatraz
by alcatraz
Found this pic of some available sizes, maybe it helps.
hambini
by hambini
It looks like the ID is too small and possibly an issue with the chamfer angle. Are you sure it's the correct bearing size (forgetting the chamfer)
Hambini
ave
by ave
I am trying to source another bearing, also found a friend who has a similar fork, will check my bearing on his fork.
In general it's the right size. Outside diameter is perfect, and I didn't find any bearing with different inside diameter with the same outside diameter.
ave
by ave
Found a new bearing in a LBS. The bearing chamfer is obviously different. New one on the right.
It fits the fork much better! (animated)
But now the gap between the frame and the fork disappeared totally, if I torque down the headset, the fork won' turn. :(
I measured the new bearing to be 49/37/6.5, so its height is 0.5mm lower.
The new one marked to be 1-3/8" ACB 36 x 45
So I'd need either a 49x37x7 36/45, or a 49x37x6.5 45/45. Neither of them exist it seems! :D
glepore
by glepore
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
alcatraz
by alcatraz
What about putting a thin shim under the new bearing?
Apart from the different chamfer, the new bearing looks shorter than the old one. If you could get the new chamfer but the same thickness you might be just right.
/a
ave
by ave
Yep, a thin shim would be great, I already asked a mechanic if it's possible to make one.
