SKF vs. NTN - fully sealed bearings
hambini
by hambini
kode54 wrote:
Tue Feb 13, 2018 7:58 pm
@hambini,
difficult to get NTN in the US, but as others noted, the Makita 6806 LLU bearings are easy to source. will I notice much of a difference?
If you spin it in your fingers you will instantly notice the difference. However that isn't representative of real life so under riding conditions I doubt you would notice or feel the difference. If you talk numbers, the LLU has around double the friction of the LLB - both numbers are small though.
The Makita 6806 LLU and power tool bearings as a whole are often C3. This one might not be but it's something to consider. In a C3 bearing the axial load capability increases at the expense of radial load capability. In essence you will create more friction purely by geometry.
I have written a section on it here. You will need to scroll down the page a bit. It's ultra condensed and simplified but should give you an idea.
https://www.hambini.com/technical-suppo ... re=default
Hope that helps
Hambini
vinuneuro
by vinuneuro
Hambini thanks for pointing that out. I'd imagine the bearing type is dependent on application. Cutting tools probably use CN bearings, but looks like this one is spec'd in a rotary hammer so it's almost certainly C3 or greater. Unfortunately since you don't get a NSK box with OE parts there's no way to know the full part number.
It's a shame bearing supply doesn't seem to be as abundant here in the US. I have almost everything for the rebuild, silly that bottom bracket bearings would hold things up. If I'm not able to find a reasonably priced US source, will order from Hambini.
'16 Spec Diverge Expert
hambini
by hambini
vinuneuro wrote:
Wed Feb 14, 2018 3:00 am
You are welcome.
When I was last in the US and needed some industrial supply (they weren't bike bearings), I used two companies. One called Fastenal and the other called Grainger. Despite having a trade account, the bearings were about the same price as in Europe. I was expecting them to be cheaper.
NTN supply in to the US doesn't seem that good. It's only an observation but NSK seem like the premier Japanese bearing supplier in the US. The hierarchy is SKF, NSK, Timken. In Europe it tends to be SKF, INA/FAG, NTN/NSK
HTH
Hambini
bobones
by bobones
Hambini, do you have an opinion on EZO bearings, which are a Japanese brand made by Sapporo Precision Group?
hambini
by hambini
bobones wrote:
Wed Feb 14, 2018 2:09 pm
Yes. They are of slightly above average quality (better than far eastern non name but not a Tier 1), the load ratings they list are amongst the highest available but in practice the bearing stiffness is not great, this indicates a geometrical or material difference. SKF and NTN bearing stiffness is higher. EZO bearing tolerances are not a patch on NTN, SKF. What I'm trying to say is if you buy an NTN/SKF/FAG/NSK bearing you will find the difference between the biggest and smallest bearing measured is ~0.001mm. On an EZO it's more like 0.009. It's still within the ISO/JIS/DIN standard and probably indistinguishable to the end user but if you are in the game of making bottom brackets/wheel hubs etc, you can feel the difference. This is the reason why I do not warrant my bottom brackets if the end user elects to replace the bearings with non Tier 1 bearing suppliers - the fit is compromised and the friction and life go in opposite directions.
A lot of cyclists have a high opinion of EZO bearings because of a blog post written by FLO cycling which is here
http://flocycling.blogspot.fr/2011/07/f ... 1-ezo.html
In my professional opinion. The above article has some very poor engineering practices: Measuring bearings with a vernier and proclaiming their accuracy levels, an L10 bearing life calculation that is completely wrong and a few more "questionable" lines of thought. I think it's reasonable to expect a wheel supplier to have an understanding of how bearings work and not make a hash of it.
I appreciate some people will be lovers of FLO cycling and EZO bearings but there are better ones out there.
If we park my engineering opinions to one side and look at the end users. I supply a number of triathletes and two racing teams with bottom brackets/wheel bearings. Almost all of them ride on NTN, there are a very small number that ride on SKF - usually unsealed bearings with oil as the lubricant. In cyclocross, it's completely different, The lion share are people riding on FAG/INA and about 30-40% on a combination of NTN/SKF. Out of the people I know who used to use EZO, all of them prefer NTN or SKF RZ.
HTH
Hambini
bobones
by bobones
Thanks, that's great information. My own personal experience is that EZO don't last particularly well in UK winter or wet conditions, so I'll be going for SKF, NTN or FAG in future.
kode54
by kode54
thx for all this valuable info. all...great to know going forward.
i have checked out your website and try some NTN bearings first.
hambini wrote:
Tue Feb 13, 2018 11:07 pm
@hambini,
Hope that helps
Hambini
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 7.8 carbon hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 4.5AR CK CL hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
mrlobber
by mrlobber
How about 4130 bearings (for 30mm cranks in PF86 frames), are they available from NTN, hambini?
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
hambini
by hambini
mrlobber wrote:
Wed Feb 14, 2018 5:00 pm
Afraid not. Shimano deliberately made their shells 41mm to prevent anyone using a 6806 bearing (which has 42mm OD). All of the conversion systems I have seen use either a 6806 bearing and grind the outside down or a 6706 bearing which is seriously thin. Both have a load rating that is 1/4 of a standard bearing. If you are putting out lots of torque, they won't last long at all.
Hambini
vinuneuro
by vinuneuro
NSK usa office says that if it is C3 it would be marked on the inner or outer race. These Makita oe bearings are marked 6806D on the seal (brown color indicating DDU) and nothing on the inner race, so they are saying that it is a normal CN bearing. I will use these and see how they go.
Fwiw, I also got the DDW (light contact seal) and in the hand the friction difference is noticeable. I imagine the no contact seals are even better. But as discussed and tested it must be some fraction of a watt so will go for the longevity.
hambini
by hambini
vinuneuro wrote:
Wed Feb 14, 2018 6:59 pm
From memory I thought they were marked on the outer race but it was such a long time ago that I saw one that I could be wrong.
Hambini
mrlobber
by mrlobber
hambini wrote:
Wed Feb 14, 2018 6:37 pm
Bastards.
Thanks for the reply. At least with BB30/BBright/BB386 we have options :thumbup:
pdlpsher1
by pdlpsher1
Hi Hambini,
I have some new NTN bearings in my Fulcrum wheels. The drag seems very high. I have about 100 miles in so far but the drag didn’t seem to decrease. Would I expect the drag to go down with more miles? I’m not sure if the extra drag is from the seals (LLU) or the type of grease fill, or both. I’m comparing the drag to the standard bearings I had that came with the wheels which are marked 2RS (except the 6803s in the freehub which only had one shield per bearing). Thanks.
hambini
by hambini
pdlpsher1 wrote:
Thu Feb 15, 2018 1:56 am
Hi Hambini,
NTN seals are very good and seal well. However at low RPM the seal friction is the dominant force. Hence if you are spinning them at finger speed then they will feel a lot more draggy (even more than SKF, NSK and FAG). At operating speed, the seal friction will remain the same but is a much lower proportion of the entire drag. This is difficult to demonstrate because the consumer typically cannot spin a bearing up to operating speed in their figures.
NTN seals also do not "lift" until you hit around 40-60RPM (depends on the size). Below that speed they are designed to statically seal whereas most others are not.
HTH
Hambini
pdlpsher1
by pdlpsher1
Thanks for the good info Hambini. If I had known about this earlier I would have removed one seal per bearing before I installed the bearings. This would have saved me half of the total seal drag. I have watched one bearing video by Oz Cycling (link provided in thread) and he found that seal drag is minuscule compared to drag from the grease. I guess I could also do the experiment myself by removing the seals on a new NTN bearing however I’m afraid of damaging the seals. I hope the seals will break-in somewhat after more miles. I also have a set of Campy Boras that don’t use sealed bearings. And those wheels spin forever compared to my other set that uses sealed bearings.
