Which countries have left hand-rear brake and right hand-front brake
Miller
by Miller
RH front brake is normal for UK though a few prefer LH front brake for that euro style.
Wasn't it Tony Rominger who experimented with swapping the cabling on his bike the evening before a mountain stage and next day got the braking wrong and stacked?
Mockenrue
by Mockenrue
silvalis wrote:
Sun Feb 04, 2018 10:52 pm
Valbrona wrote:
Sun Feb 04, 2018 7:26 pm
We had an Empire. Like in Star Wars.
Did you have a death star too ? :D
Yes, but then they found the thermal exhaust port. It's called Brexit :|
hogehoge
by hogehoge
@shonanmike
Japan is front brake right
euan
by euan
Some old school CX racers used to run their CX bike and road bikes front brake RHS.
Mainly because if you are braking while dismounting on the NDS, the rear gives better control
themidge
by themidge
Miller wrote:
Sun Feb 04, 2018 10:58 pm
Yes! I just read that in a biography of Miguel Indurain :D
robertbb
by robertbb
I went over the handlebars when I rented a bike in San Fran about 10 years ago.
Stoopid yanks ;-)
XCProMD
by XCProMD
In Italy, right hand front brakes could be found until the early ‘90. I remember Bianchis routed like that, and Gianni Bugno being one of the cyclists using such configuration.
Inviato dal mio iPhone utilizzando Tapatalk
Digger90
by Digger90
Here's a related short video from the BBC today about why the UK drives on the left side. Interesting that most countries did so until not so long ago...
http://www.bbc.co.uk/news/av/uk-england ... n-the-left
XCProMD
by XCProMD
In Sweden we changed overnight... No one got killed!
Skickat från min iPhone med Tapatalk
Stickman
by Stickman
Japan front brake left.
I discovered that when doing a bike tour in Japan :D Coming from Australia, with right hand front brake, took a tiny bit of brain adjusting. Always check your brakes before riding off when riding a different bike :)
Stickman
by Stickman
hogehoge wrote:
Sun Feb 04, 2018 11:22 pm
@shonanmike
Not the bikes my wife and I rode last year! Is that from the shop? I wonder if the guy we did the group ride with does his own mechanic work and routes them whichever is his preference.
Hellgate
by Hellgate
I've ridden motorcycles for years. I switched my cabled so the front brake lever is always in my right hand.
Sent from my ONEPLUS A5010 using Tapatalk
shimmeD
by shimmeD
I also rode motorbikes. I'm in southern hemisphere but prefer R rear. I guess I could change if I ever wanted to ride a motorised 2-wheeler again.
Less is more.
FTPWhor
by FTPWhor
Right hand front brake is the norm in India.
NickJHP
by NickJHP
In Australia we drive on the left, so I always setup my front brake to be operated by the left-hand lever. That means I can use my right arm to indicate a right-hand turn across traffic while still having use of the most effective brake.
With rim brakes, having front lever on the left and rear on the right also gives a better path for both the front and rear brake cables. The front cable exiting from the handlebar tape has less of a curve to get to where it enters the brake arm, and ditto for the rear cable, which always runs down or enters/exits the top tube on the left-hand side.
