DA9150 with SRAM 11-32T Cassette
ryanw
by ryanw
Calnago wrote:
Sat Feb 03, 2018 9:40 pm
ryanw wrote:
Sat Feb 03, 2018 9:29 pm
Just watched a video on YouTube with a guy running a 46T chainring and a 36T cassette with 9150.
Link? I'm curious as to what it looks like.
https://youtu.be/rQbhMaveqcw
'16 Cervelo S5 - 6,650g
'17 Focus Mares Force 1 - 7,800g
‘18 Ibis Ripmo - 13,870g
Calnago
by Calnago
Ok... confirms what I said earlier... that you'd have to crank that B-screw all the way in, which pulls everything away from the cogs and is most noticeable when you're working in the small cog range (look at the gap between the upper pulley and the smaller cogs... its' huge). And if you're going 1X, you'd want to be able to use the Big/Big combo anytime, anywhere... not just on those rare "don't tell anyone" occasions when you know you should probably be in your small ring (which you won't have). I also think that the max cog for the new derailleurs (without the GS cage) is 30 teeth, not 32. I'm getting confused without looking it up now, so I may be wrong there. So, if you did go this route, I'd for sure try to get a GS version of the derailleur for better performance across the entire range of the cassette.
Anyway, up to you of course. You can't expect smallish cassette road type shifting performance on a cassette that large anyway.
pdlpsher1
by pdlpsher1
I recommended the OP to get a GS RD but the GS is only available on the Ultegra RD. And the OP doesn't want a second tier component on his expensive bike.
Another option is to run the eTap WiFli which will support a 11-32 cassette I believe.
Calnago
by Calnago
Ah yes... I missed that. Shame... cuz the GS option is the way to go. But what is really "second tier" in this case... something that is designed for and works with what you want to run... or something that is more expensive but performs worse in the same scenario?
spdntrxi
by spdntrxi
how about add a ceramicspeed cage.. I know in the etap world Ive seen a number of people use it with a 32t. That way you can keep it top tier.
I just looked and it's advertised to work with 32t for the 9150
aaric
by aaric
Can also just use a Di2 XTR rear derailleur, and easily run a 42T rear cassette...Maybe as large as a 46.
TurboKoo
by TurboKoo
spdntrxi wrote: I just looked and it's advertised to work with 32t for the 9150
I don’t know where have you got that information but it’s wrong
Scott Foil
Shimano 9150
Shimano FCR-9100-P
Shimano C60 tubulars
tonytourist
by tonytourist
He meant with the OSPW setup from Ceramic Speed
http://www.ceramicspeed.com/sport/produ ... %20Shimano
"A special OSPW System has been designed for the Shimano 9100 and 8000 series (it's NOT compatible with the R8000 GS), featuring a 13/19-tooth combination and accommodating cassettes of up to 32t."
spdntrxi
by spdntrxi
TurboKoo wrote:
Sun Feb 04, 2018 8:55 pm
so basically you skipped the sentence above .. or what :noidea:
TurboKoo
by TurboKoo
spdntrxi wrote:
Sun Feb 04, 2018 11:57 pm
I'll just get my coat
Scott Foil
Shimano 9150
Shimano FCR-9100-P
ryanw
by ryanw
Tested out some gearing yesterday and have come to the conclusion that I don’t need a 32 for what the bike will be used for.
Buying the DA11-30 cassette with a selection of front rings (46, 48 & 50). Will go from there and IF I feel the need for more gears, the SRAM 32 is always a safe backup plan.
On a side note, I will be fitting a fill CeramicSpeed drive chain to this (OSPW, BB, chain).
alcatraz
by alcatraz
Sometimes setting the B screw too far in also shortens the distance between pulley and cassette. Sometimes you need it set further in than max which means you replace it with a longer or turn the screw around to the other side.
Without a cable attached and b-screw barely inserted you can easily move the derailleur with your hands. Check which angle it needs to maximize the gap.
I recently installed a sram red mid cage derailleur on a friends bike running an x1099 36t cassette. His bike has a fairly long hanger so this is barely possible.
I almost gave up at first because the pulley was too close to the cogs at max/mid setting B-screw. Then after checking the geometry for a while I noticed where the B-screw needs to be to maximize the gap. It took a few tries but I got it to a point where it just works and the drivetrain is silent.
If it were too small the jump from 2nd to 1st would be noisy and potentially dangerous as the chain is wedging/crushing the derailleur open past it's range.
In order to measure where the largest gap is you just need to set the low gear limit screw so you can hold the derailleur over the largest cog. Then in this position you swing it around its mounting bolt axis and see where the gap is largest. Set the B screw to default the derailleur to this position.
If it's still not large enough get a road link or another derailleur. Changing the cage usually only helps with chain slack (gear total capacity). It doesn't help with clearing a large cog.
/a
