Typical Madone build weight, ?<7kg
alanmclean
by alanmclean
Hi
How easy/expensive is it to get a self-build Madone 9 below 7kg?
Current bike is old, non-aero but sub 6.8. and loves hills.
Thinking of going for something completely different: Madone H2 frame with Ultegra Di2, 1600g wheelset etc. Could I get this below 7kg without selling a kidney?
I may turn 180deg and go for Emonda or similar but am intrigued by all the new tech around and am considering an aero bike for fast bunch rides while accepting a small weight penalty on the hills. But I don't want a 8.5kg monster. I'd be grateful for any real weights, either factory or self-builds.
Of course I'd like two superbikes but can only afford one.
Thanks in advance
Alan
Wookski
by Wookski
A riding buddy just built up a H1 RSL to < 6.9kg with Dura-Ace Di2 and 404’s.
Q: with riding position having such an impact on drag why wouldn’t you get the H1?
OliverRB
by OliverRB
Weights are given on Treks site, sounds like your building something close to the 9.5 build, comes in at around 7.5kg in the 56.
You can get the weights of all the components on the trek site and then just adjust from there.
Noctiluxx
by Noctiluxx
My buddy just built up his size 52 Madone 9 (Series 600, H2) with Dura Ace 9150 di2, Zipp 404 NSW's, Bontrager Madone XXX Integrated bar, Bontrager XXX carbon super light saddle, and Speedplay Zero Titanium pedals. Total weight 6.9-KG.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2016 Specialized Allez DSW Sprint (Gold)
alanmclean
by alanmclean
Thank you very much for replies. Sounds like a 500g penalty for the hi tech frame. I found some nice links to other threads too. Great forum as usual.
Kaboom
by Kaboom
Its gonna be pretty hard to build ANYTHING sub7 with 1600g wheels...
plpete
by plpete
I'm gearing up to build up a 54 H1 Madone RSL with Di2 Ultegra and some Aelous 5 clinchers. Will document my build for sure.
izza
by izza
plpete wrote:I'm gearing up to build up a 54 H1 Madone RSL with Di2 Ultegra and some Aelous 5 clinchers. Will document my build for sure.
I’ve done a 58 H2 with etap and the Aeolus 5 clincher wheels. Came in at 6.9kg. You should clear that easily.
Noctiluxx
by Noctiluxx
What's the weight difference between Series 600 and Series 700? Also is H1 lighter?
FIJIGabe
by FIJIGabe
I think the difference clocks in at about 100ish grams, depending on frame size (larger frames will have a larger difference in weight). H1 is lighter.
Emonda SLR (under construction), Madone 5, Cobia. I own a lot of Treks.
coolman2001
by coolman2001
From what I have seen and heard, the difference in weight between h1 and h2, 600 vs 700 is 100 to 120g.
