New cannondale SYSTEMSIX road frame!
Svetty
by Svetty
gwilson wrote:
Mon Nov 26, 2018 4:16 pm
Only downside I would really give so far is that the front end is a little on the harsh side, but hey it's a performance aero bike, not an endurance bike. I ride it with 25mm GP4000SIIs at 100 psi (I weight 82kg) so would be interested if lower tire pressure (maybe tubeless)
I'd not put more than 80-85 psi in the front tyre at your weight.....
Dan Gerous
by Dan Gerous
Agreed, 100psi on the front is high, especially with higher volume tires like the 25mm GP4000sII on a wide rim.
66freddy66
by 66freddy66
Hi all, does anyone know the full spec for the KNOT System handlebar? ie the reach (75/80/85mm?) and the drop (120/125/130mm) and also the degree of the KNOT stem, -17/-8/-6/8? I have a himod frameset on order and have everything i need to build up my dream bike (etap group set, fizik saddle, quarq power meter, 60mm carbon wheels) to go with my Supersix Evo Himod 2016 team bike however ive yet to make my mind up on a cockpit set up.
I ride the supersix evo with a slammed 6degree 130mm long stem and want to get the same reach and stack if possible on the systemsix but the biggest KNOT stem is only 120mm but if its Negative degree and the KNOT Bars are a long reach then i may be ok?
Many Thanks. Freddy
Dan Gerous
by Dan Gerous
The stem is -17° designed to be perfectly horizontal so less in the wind (which is kind of ruined by the poorly design Garmin mount that sticks the computer super high IMO). Didn't Damon post the width/drop/reach specs earlier?
Stitchking
by Stitchking
66freddy66 wrote:Hi all, does anyone know the full spec for the KNOT System handlebar? ie the reach (75/80/85mm?) and the drop (120/125/130mm) and also the degree of the KNOT stem, -17/-8/-6/8? I have a himod frameset on order and have everything i need to build up my dream bike (etap group set, fizik saddle, quarq power meter, 60mm carbon wheels) to go with my Supersix Evo Himod 2016 team bike however ive yet to make my mind up on a cockpit set up.
Many Thanks. Freddy
Don't get the knot cockpit its ugly as sin. Might be fast but there is only so much aesthetic you should be willing to give up for speed.
Sent from my SM-G935F using Tapatalk
refthimos
by refthimos
EVO | 5.37kg
SystemSix | 8.01kg
TCR Advanced SL Disc | 7.35kg
P5 | 9070 Di2 | SISL2 SRM | Enve 7.8 | Alto Disc
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
66freddy66
by 66freddy66
Stitchking wrote:
Thu Nov 29, 2018 6:50 pm
Many Thanks. Freddy
any suggestions of what other cockpit set up youd go for? need a 130mm stem and bars no wider than 420mm? Intergrated bar and stem would be nice but open to suggestions on seperate stem (which you can route cables through) and aero bar combo?
Stitchking
by Stitchking
Many Thanks. Freddy
I built one up with the lighweight pro aerobar. The cables were actually really easy to run through the bar and you barely see them to be honest. That an a pro vibe stem is a great combo. Or the new enve aero cockpit looks good too.
Please excuse the photo quality and messy workshop hahaImage
ch00bzs
by ch00bzs
Guys, i was wondering. if you turn your handlebar, a part of the fork, near the lower headtube side, on the crown, there's a gap. If im going to ride in the rain, there's a chance that water will stuck there.. or is there any way to drain the water ?
DamonRinard
by DamonRinard
Hi ch00bzs,
The opening is what lets the cables go inside. And yep, water gets in (like it eventually does in other forks anyway) and comes out through the drain holes at the bottom of the fork.
Cheers,
Damon
Damon Rinard
Engineering Manager, Road Bikes
Cycling Sports Group, Cannondale
Ex-Kestrel, ex-Velomax, ex-Trek, ex-Cervelo
DaiD
by DaiD
Hi Damon,
Thanks for spending the time and energy to answer questions here :thumbup:
Hopefully this is a very quick one to answer - can you flip the seatpost on the System Six, so that the layback is facing forward? I'm selling my current bike [well, hoping to!], and was looking to get a TT bike, but if this allows a very similar position then I'd definitely be interested...!
Thanks again
DamonRinard
by DamonRinard
DaiD wrote:
Thu Dec 06, 2018 1:05 pm
Hi Damon,
Thanks again
Hi DaiD,
Thanks, I'm happy to help!
The seatpost is an important contributor to the low drag of the SystemSix because we gave it a specific airfoil shape. One consequence of that shape is that it's not flippable. Although the SystemSix's low drag makes it seem attractive as a TT bike, most riders will find their best TT position on a TT bike not a road bike.
Cheers,
Damon
Damon Rinard
DaiD
by DaiD
Hi Damon, thanks for your reply. Damn! Hmm, maybe two new bikes then.... :D !
DamonRinard
by DamonRinard
DaiD wrote:
Sun Dec 09, 2018 7:52 pm
Indeed!
N+1, or as they say about hard or soft tacos, "porque no los dos?"
Damon Rinard
CAAD8FRED
by CAAD8FRED
What are the risks of internally running mechanical shifting wires?
