New cannondale SYSTEMSIX road frame!
Systemsix has 47.5mm wide down tube.
The aero bottle width taper a bit (not completely flat) but it's 55mm in the middle.
Regular round bottle is 73mm wide, with possibility that there's also bottle cage extend sideway past the bottle further.
surely anything will be more aero than a round bottleHow wide is the downtube on the System Six? I'm thinking about getting the bottles for my S5, but I don't think it'll be a very good fit due to the downtube tapering as you get closer to the head tube.
https://www.aero-coach.co.uk/water-bottle-testing
looks good, have ordered, bottles arrived today but driver didn't leave the cages so have to wait a few days for them to be redeliveredHexsense wrote: ↑Thu Apr 20, 2023 12:23 amYes, it fits perfectly on my size 51 SystemSix. The bottle width match well with SystemSix's downtube width.danridesbikes wrote: ↑Wed Apr 19, 2023 6:53 pmanyone picked up a Gripper Aero & ReGrip Aero Bottle & Cage?
- robbosmans
- Moderator
- Contact:
Its just a paintjob
anyone running 28's on Knot 64s?
they are running 28mm Corsa Pros on the LAB71 supersix evo's at the Giro, on Vision wheels (21mm internal, the same as knots, but 31mm external v 32mm) not sure what Ben Healy was running today on the systemsix though, anyone know?
Did C-dale publish test results for this aero bottle/cage combo?danridesbikes wrote: ↑Wed Apr 19, 2023 6:53 pmanyone picked up a Gripper Aero & ReGrip Aero Bottle & Cage?
pic of mine while i'm here
mercy care atlanta
A friend wind-tunnel-tested (straight on only so no yaw angles greater than 0) a regular 650ml round water bottle/Zipp carbon cage on the downtube of his Factor Ostro vs the 440ml Aero vault bottle/cage mentioned in the article and found 1.8w difference... which speaks to the ongoing frustration I have with often exaggerated claims by those selling aero products and or services.
With that minimal saddle to bar drop I'm not convinced an aero bike is the ideal choice if you have a bad back, mostly race on dirt/unpaved and like to climb
I'm curious if he tested with or without a rider on the bike, as in road position that adds allot of noise due to the position being much more variable than a TT position.user83843 wrote: ↑Sun May 14, 2023 12:14 amDid C-dale publish test results for this aero bottle/cage combo?danridesbikes wrote: ↑Wed Apr 19, 2023 6:53 pmanyone picked up a Gripper Aero & ReGrip Aero Bottle & Cage?
mercy care atlanta
Not really sure any of it matters anyway outside of a long Merckx TT? I don't know any mass-start racers who use proprietary bottles like Fidlocks or aero bottles. Maaaaybe the Cannondale squared off bottles since the cages can carry normal bottles too, but the special bottles might be a little annoying to replace if you discarded one in the feed zone and a random person took it.
That's the crux of those bottles for me - I'd love to shave a few watts off (and on an Evo II, there are plenty to take...) and the clever idea of a cage that takes both the Gripper Aero and standard round ones is brilliant, but the idea of having to buy a half a dozen of those slab-sided bottles and organizing it with helpers to get through a race (and trying to retrieve them afterwards) to save IIRC 3w...TobinHatesYou wrote: ↑Sun May 14, 2023 2:07 am
I've dabbled with Elite Crono bottles previously for Merckx-style TTs, more as a means of carrying fluid to and from the race. To be frank, I'm still unsure whether there is a real-world time saving for using those over a standard round bottle (as there are tons of time being wasted at fiddling with them) for hydration and not only as a fairing with fluid storage.
thats what swung it for me, i use my bike on the turbo, so the ability to use a regular larger bottle for longer sessions was a win,Maaaaybe the Cannondale squared off bottles since the cages can carry normal bottles too,
and when you switch from regular to the cannondale shaped ones, there is a very noticeable difference in the size and profiling, so while gains will be minimal because the cap is still the same size, they are likely still there
snap, until one bounced off and killed itself 50km into a 330km ride, in hindsight, running something proprietry on a ride like that was stupidI've dabbled with Elite Crono bottles previously
No rider, just the bike tested 5x with each configuration to establish averages. I'm going back with him to analyze a couple semi aero climbing bikes vs fully aero. Also to look at watt savings for 38 vs 42 and 44mm bar widths as well as hidden vs exposed cables.
https://efprocycling.com/racing/bike-ch ... systemsix/
EF says it's lab71 systemsix, so I presume new carbon rather than just a paint job
- robbosmans
- Moderator
- Contact:
Its a just a paintjob
> super narrow 38 cm barspokhim wrote: ↑Tue May 23, 2023 10:11 pmhttps://efprocycling.com/racing/bike-ch ... systemsix/
> short 170 mm cranks
