Hexsense
Hexsense
by Hexsense on Fri Apr 01, 2022 4:46 pm
Less comfortable than Supersix so I lower tire pressure a bit to compensate.
I can't tell if it's more aero in straight head or tail wind.
But it feel more aero in crosswind.
The handling (cornering and etc.) feel familiar which is not surprising as they both have 71.2degree HTA + 55mm fork offset.
MaEdCo
by MaEdCo on Tue May 03, 2022 4:31 pm
DamonRinard wrote: ↑Mon Oct 29, 2018 12:05 am
Hi gwilson,
Glad you like your SystemSix!
The axle you linked won't work, because Speed Release axles are M12x1
double-lead thread, while most trainer axles are
single lead. (The double lead is what makes Speed Release twice as fast to install: half the turns.)
But there's a workaround. Install this RD hanger, Cannondale part number KP419/, and the axle you linked seems like it should work.
https://www.cannondaleexperts.com/Canno ... _5509.html
This hanger, originally designed for Slate and Beast of the East, has single lead threads, so it fits the trainer axle. One nuance is the rear hub axle sometimes jams on the hanger's inside boss, but slip it past and it works.
As usual, be sure the trainer axle fits the left dropout as well. Speed Release is flat, while some others have a cone.
Cheers,
Damon
hello, sorry for bump this... but I really need a smart trainer for my Cannondale SuperSix EVO, as of today, which one can you recommend for less than 400 dollars? thanks
MaEdCo
by MaEdCo on Thu May 05, 2022 2:46 pm
Hexsense wrote: ↑Tue May 03, 2022 4:40 pm
Used Wahoo Kickr Core can sometime go around 400. Keep finding.
I found a deal on ebay a Kickr Snap with the KICKR SNAP 142 Adapter M12x1.0 Fine, it will work? or do I also have to buy the "Cannondale Derailleur Hanger for Slate and Beast of the East Rear X12 - KP419" ?
Hexsense
by Hexsense on Thu May 05, 2022 5:38 pm
M12x1.0 doesn't fit Mavic speed release through axle.
So, you'd have to change RD hanger to change RD hanger to use more common axle standard. And I'm not sure if axle you propose fits.
Just find Kickr Core. Don't get Snap. If anything, it's way quieter and nicer to use.
MaEdCo
by MaEdCo on Thu May 05, 2022 9:52 pm
Hexsense wrote: ↑Thu May 05, 2022 5:38 pm
this is my rear axle from my Cannondale SuperSixEvo
is way to expensive for me, I'm gonna keep looking for something cheaper...
TriJoeri
by TriJoeri on Fri May 06, 2022 1:53 pm
Does anyone who has the Robert Axle Project leverless thru axles have the part numbers for the front and rear thru axle they ordered? I'm a bit unsure if I have the correct ones in my shopping cart a.t.m.
