Canyon Aeroad Disc - Tire Clearance
Bordcla
by Bordcla
I live in Quebec. A lot of times I think to myself they should just rip off all the asphalt and leave it on dirt. Wouldn't be worse...
@dcorn: thanks a million! It would seem that there is ample room for the 28mm Conti's in there!
dcorn
by dcorn
Oh, and even with all that clearance at the fork, 36mm Clement MSO gravel tires do not fit. I pulled the front wheel off my Crux and stuck it on the Canyon just to see how much clearance there really was. If I ever get my 2nd wheelset back from the shop with 32mm Hutchison Sector slicks, I'll try those on for size. Unfortunately the rear hub on the Crux is SCS, so I can't swap it into the Aeroad to test.
spartan
by spartan
does anyone know why canyon bikes do not sell in Canada? 2 years ago Canada signed a free trade agreement with European Union.
Current Rides:
2017 Giant TCR Advanced SL 0 DI2 9150
Bordcla
by Bordcla
dcorn wrote:
Mon Feb 05, 2018 11:37 pm
Thanks! Although the cross tires wouldn't fit, am I correct in assuming that 28mm Conti's (+-31mm mm actual) are ok front and rear?
TonyM
by TonyM
spartan wrote:does anyone know why canyon bikes do not sell in Canada? 2 years ago Canada signed a free trade agreement with European Union.
And Canyon ships their bikes to almost all countries in the world!!!!!
I move 2 years ago to Canada and honestly I am quite surprised to see many brands not shipping to Canada or not represented in Canada. For example Sportful, a sister brand from Castelli and used by many Pros, doesn‘t ship to Canada and doesn’t even have a distributor here. Lightweight is also not shipping to Canada (they have now at least a few dealers).
Something seems to be complicated in Canada so that manufacturers don‘t ship to Canada.
MayhemSWE
by MayhemSWE
spartan wrote:
Tue Feb 06, 2018 1:21 am
Most likely because Canyon does not want to deal with customer service for a market where they have no local representatives. Don't think the US assembly plant is quite up and running at full capacity yet but when it is I'd expect them to open a Canadian office sooner or later…
Marin
by Marin
Bordcla wrote:
Wed Jan 31, 2018 6:59 pm
28mm Continental GP 4000s II tires
Careful, GP4000s 2 are huge, the 28s come out to 31mm on 17c rims. 25s are already 28+ mm wide on most modern rims.
dcorn
by dcorn
The only thing I can't say for sure is how tall of a tire the bike can take in the rear. The gap between 25c tire and seatstay cutout is at least 5mm, so chances are you'll be ok. I just don't want to buy a tire and mount it just to answer a question online :)
You definitely have space for a 2mm per side wider tire in the rear and the front has tons of room on the sides and top.
Bordcla
by Bordcla
As for the rear, I think that the answer was provided here:
http://road.cc/content/review/217032-ca ... isc-80-di2
See picture on page 2 of the comments section.
cyclotron8000
by cyclotron8000
Bordcla, I've just seen this thread after what we've been saying in the other one. I'm also trying to get a Canyon in Canada (Vancouver). Seems we're trying to accomplish the exact same thing!
It looks like 28mm will be absolutely fine, depending on the wheel. I intend to ditch the Reynolds wheels for something a little wider, so I may run into problems, but I also intend to go tubeless, so many a Schwalbe 28mm is the solution.
TonyM
by TonyM
cyclotron8000 wrote:
Fri Feb 09, 2018 1:17 pm
Which wheel set are you thinking about?
BTW, do you know if you have to pay customs (additionally to the 7% GST) on the Bike when importing it to Vancouver from the US?
Bordcla
by Bordcla
While I have little concern about 28s generally, I wanted to make sure that 28 mm Conti GP were not a problem, because at 31mm wide and 29mm tall on a 27c rim, they are so big as to he 28s in name only. But those are the tires I like (durable, fast rolling, grippy in wet or dry conditions, comfy, easy to find and cheap).
Hexsense
by Hexsense
Bordcla wrote:
Fri Feb 09, 2018 6:39 pm
As far as i know, there is non exist 27mm internal width road rim yet.
And if you are talking about external width, that's meaningless for tire width.
Zipp 404 NSW have 27.8mm external width but only 17mm internal width,
an alloy rim, Velocity Aileron is 25mm external width but 20mm internal width so the tire will be wider on this rim than on wider external width Zipp above.
Roval CLX 50, Light-Bicycle 46mm and Venn Rev 50 have internal width around 21mm,
Enve 4.5 AR Disc have internal width of 25mm (hookless) are the widest internal width road wheel at the moment as far as i know.
Curious to know which rim will push the envelope that far as offering 27c rim.
TonyM
by TonyM
Hexsense wrote:
Fri Feb 09, 2018 8:04 pm
He meant 17c rims I think.
Bordcla
by Bordcla
Correct. Typo. 17c. Not 27c.
