tour mag aero test 2018
L3X
by L3X
Just messing around with their data, there surely are some interesting things to highlight:
-When trying to predict the total times for flat/hills/mountains based on CWA, there's a very strong positive correlation between the two. Aero matters less when including more climbing meters into the simulation
-When trying to predict the total times for flat/hills/mountains based on weight, there's a quite a strong negative correlation for both the flat & hills data, and no reasonable correlation for the mountain data. Interestingly the correlation in all cases is negative, i.e. added weight reduces the overall time in all 3 scenarios
wingguy
by wingguy
spartan wrote:
Tue Jan 30, 2018 5:03 am
the aero data graph is quite revealing. the super exotic zipp 454 nsw is less aero than the 404 fc. :lol:
Something strange going on there. In the simulation results the Aeroad is clearly shown as faster on all 3 courses with the 454NSW than 404FC, even though the FC is shown as lower drag and the calculated effect of the 165g weight penalty should be miniscule on the flat and rolling profile...?
spartan
by spartan
yes i also noticed this discrepancy. could it be weight? the stock 404 are quite heavy ~1650gm
Current Rides:
2018 Madone SLR DISC DI2 9XXX
2017 Giant TCR Advanced SL 0 DI2 9150
Marin
by Marin
On the Tour forum some people are suspecting there are errors in the tables (data swaps).
Shrike
by Shrike
Thanks Marin, didn't know Tour had a forum. Makes for interesting reading, lots of solid questions posed.
The translation is good enough to read clearly:
https://translate.google.co.uk/translat ... rev=search
Marin
by Marin
Here's the actual thread (that I happened to start): http://forum.tour-magazin.de/showthread ... ests/page5
Bordcla
by Bordcla
So, on the slowest bike (Giant TCR), one saves a minute on every parcours by keeping the stock 30 mm wheels vs switching to the pricey 404 FC. Aerodynamically speaking, how does that make any sense?
Greatest difference between fast bike and slowest bike is about 4 minutes on about 3 hours +. Which is to say, in a long triathlon, ride a tri bike with deep wheels. In a fast time trial, ride the best bike you can buy, disc wheel. For everything else, the difference isn't that great at all... Ride what you like and enjoy it!
bllx
by bllx
Was the same model of tire used for all test, or were stock wheels tested with stock tires?
wingguy
by wingguy
Bordcla wrote:
Fri Feb 02, 2018 2:51 pm
Very odd, especially since the Propel with deep section stock wheels is the other way around.
Either some of the data rows have been switched around or the simulation gives waaaay too much bias towards wheel weight...
Beaver
by Beaver
There are definitely mistakes in the list, not only that the Giant TCR is faster with 30mm stock wheels instead of the 404...
Source: https://translate.google.com/translate? ... 45739.html
Maybe they will publish a corrected one later.
thumper88
by thumper88
cunn1n9 wrote:
Wed Jan 31, 2018 8:05 am
Everytime they run these tests the data seems to change slightly. They did a test a while back on the F10 and found it was as fast as the Madone. Now there is a different result. There is not a big difference which tells me that the margin of error in the wind tunnel is probably around 10W and that all the bikes in the top tier - Madone, F8/10, S5, etc are so close it doesn't matter.
Thoughts?
Whatever the variations in test methodology, they were probably close to the end of the scale that was optimal for the F10 in that particular test earlier that got a lot of Pinarello fanboys excited.
It's just not in the same ballpark as true aerobikes. More of an all-arounder with some nods to aero like SL6 or R5. Super competent bike but not an aerobike.
Hexsense
by Hexsense
RyanH wrote:
Wed Jan 31, 2018 6:21 am
It puts things into perspective a bit better to understand that we're comparing 411w for one frame vs 406w for another. Not nearly as significant.
So just few watts from Giant TCR against Trek Madone?
Well, that almost make me want to just select a frame based on ride quality rather than aero quantity then.
PS. seems like they fixed their data.
happyon2wheels
by happyon2wheels
This :thumbup:
guyc
by guyc
Hexsense wrote:
Thu May 03, 2018 6:39 am
That should always be your approach unless you ride for a living anyway.
bm0p700f
by bm0p700f
When doing 25mph I have to put out alot more than 200w. The differences are not that great between bikes
It is also interesting that the zipps do not drop the CDA for all bikes. For the first few CDA rises with the zipps. I presume that means the stick wheels are more aero in these cases unless there is some odd interplay between wheels and frame.
