tour mag aero test 2018
wheelsONfire
by wheelsONfire
If every bike would be set up for same stack and same reach it would be more fair.
The aero fan would probably swap stem(s) while the not so aero would use spacers.
Otherwise, how can data be measured correctly?
Bikes:
Open *UP* (2016.04.14)
Hexsense
by Hexsense
I'm still quite puzzled to understand why TCR perform so poorly.
Consider Specialized claims that both new Tarmac and Allez Sprint is as aero as their first gen Venge.
The TCR also aero seatpost and some tube shape doesn't look too different to the Allez Sprint. Why didn't it perform any closer to the Venge.
Why does it even slower than Emonda and Scultura which has absolutely no aero profile anywhere.
Beaver
by Beaver
The Émonda wheels have higher rims, less spokes and no discs. The frame has an aero headtube and the seattube is shorter, that should be a few watts.
And the time differences are also influenced by the weight, so 5.94kg vs. 6.84kg.
And they both share a wider than tall downtube and big gaps between frame and wheels - that's not quite aero and the difference to the Tarmac SL.
wingguy
by wingguy
Hexsense wrote:
Thu May 03, 2018 5:23 pm
Just look at one from the front. Gigantic, square downtube. Most climbing bikes these days have at least some sculpting of the DT, some kind of Kamm tail or tear drop shaping or osftening of the shapes, the TCR (which I actually really like as a bike) just has a massive brick from the HT all the way to the BB. I wouldn't be surprised if the last gen Protos is the only thing measurably less aero than the TCR. :noidea:
spartan
by spartan
the next gen of the tcr advanced will use a more aero downtube just look at the giant liv lagma.
Current Rides:
2023 Tarmac SL7 Di2 9270
ex 2019 S-works SL6
ex 2018 Trek Madone SLR Disc
ex 2016 Giant TCRAdvanced Sl
ex 2012 Trek Madone7
JScycle
by JScycle
Post edited: original deleted
Why bump a post if the most recent activity is only 4-5 hours old?
TobinHatesYou
by TobinHatesYou
Post edited - original has been deleted.
It’s a spambot.
DWatkinsBSB
by DWatkinsBSB
3 posts. Joined today. Look forward to his "for sale" post.
by Nefarious86
DWatkinsBSB wrote:3 posts. Joined today. Look forward to his "for sale" post.
Sorted ;)
Sent from my SM-N950F using Tapatalk
Using Tapatalk
Beaver
by Beaver
In Tour magazine issue 3/2018 they tested the Rose X-Lite Four with 60mm DT Swiss wheels 212 watts - compared to 208 watts for the Madone with 50mm Aeolus 5 issue 1/2018. Did they change the setting?
TobinHatesYou
by TobinHatesYou
Beaver wrote:
Fri May 04, 2018 12:39 pm
Nope. The tests were completed in the 200-240 watts range depending on the bike.
Beaver
by Beaver
The quite equal Tarmac SL had 221 watts, so 9 watts difference and then only 4 watts difference between Madone and X-lite? :D What do I miss?
What's the secret ingredient? :mrgreen:
markb9
by markb9
Do you maybe know if they tested Canyon Aeroad with the same/similar methodology?
Correct me if I am wrong, but DT Swiss arc 62mm wheelset is about 2w faster compared to their 48mm(data from swisside) , which means that ‘’real’’ comparison would be 208 watts versus 214. It really doesn’t seem like a lot and is in line with Rose numbers (that X-lite is about 4-5 watts slower compared to their aero offering).
Beaver
by Beaver
The gallery shows the numbers with stock wheels: www.tour-magazin.de/raeder/rennraeder/r ... 08636.html
So 211 watts and only one watt difference to the X-Lite (with the more aero 404 FC instead of 454 NSW maybe two watt). Seems quite odd.
eforce123
by eforce123
lots of info on here. Still unsure why specialized is so popular but doesn't seem to be better in any area. Beautiful and solid bikes though
