46/30 chainset with Di2?
vinuneuro
by vinuneuro
This will be on a road/gravel bike. I have settled on 46/30 chainset to use with Di2, but would a braze-on front derailleur be able to shift this without any issue? The question is mech height vs. small ring size.
'16 Spec Diverge Expert
ooo
by ooo
FD-R8050, FD-6870 are officially compatible with 46-32 (FC-U5000-2) crankset, so 46-30 should be ok
If your braze-on is too high you may need WickWerks Fit Link
vinuneuro
by vinuneuro
Thank you! At least that WickWerks Fit Link should provide a way out should there be some problem.
stormur
by stormur
R U sure you cn put FD so low on road frame ?
Other thing, I wouldn't expect "proper" shifting from 16t difference goint from very ( for the road ) small lower chainring (30).
Mark Twain
fa63
by fa63
I tried to fit a 46-tooth crank on a Trek Emonda, and the braze-on mount wasn't even close, but that WickWerks Fit Link looks like it could work.
vinuneuro
by vinuneuro
stormur wrote: ↑
Mon Jan 29, 2018 12:30 am
fa63 wrote: ↑
Mon Jan 29, 2018 12:55 am
Specialized spec'd this frame with 48/32 in it's last year year (my 2016 came with 50/34) and has continued it with the new generation Diverge, so I'm hoping the 46/30 will be ok even without the adapter.
ooo
by ooo
Not all braze-on can be lowered to the needed location
To be safe it is better to get frame with round seattube
Alu Diverge have round seattube, but this is less common for carbon
