6800 vs. 8000 - Chainring Spacing
Time VXRS Ulteam (7.16 kg)
viewtopic.php?f=10&t=120268
The 9100/8000 chainrings are 0.4mm further apart than they were on 9000/6800 cranks. The inner ring has been moved the 0.4mm inward to help cope with the wider hub spacing of disc hubs and shorter chainstays.
It's 0.4mm - it shouldn't make much of a difference in the real world at all, I shouldn't think. There have been plenty of WorldTour teams running 9100 front and rear derr's with SRM's 9000 based powermeter and I cannot imagine they would have done that if there was even the slightest hint of problems.
Yeah, Shimano always stated that the 9100 front mech is backwards compatible with the 9000 chainset so it should run perfectly well.BdaGhisallo wrote: ↑Sun Jan 28, 2018 4:57 pmIt's 0.4mm - it shouldn't make much of a difference in the real world at all, I shouldn't think. There have been plenty of WorldTour teams running 9100 front and rear derr's with SRM's 9000 based powermeter and I cannot imagine they would have done that if there was even the slightest hint of problems.
According to Shimano the reverse is not the case, the 9000 FD shouldn't be used with the 9100 rings. Tbh I'd be surprised if it didn't work almost as well in the majority of situations though.
Same. I'm using 6870 FD (with clamp adapter) with R9100 rings. No problem. The problem seems to come up with FD tabs that are further away from the centerline of the frame than Shimano's spec.
