Parlee and Cane Creek headset?
Nejmann
by Nejmann
Hey guys.
Can you guys help me out here. :beerchug:
I'm in a need of a headset for a Parlee Z5 SLi. I did take a look at cane creeks, but it's a jungle.
The headtube is 4 cm (maybe 4.1) at the top and 5cm at the bottom where the fork is integrated.
Can you guys tell me what complete headset i need? There should be a 15mm top cop on it.
Thanks!
JimV
by JimV
It's a Cane Creek, but I don't remember which one. I would give Parlee a call on Monday.
Nejmann
by Nejmann
Could it be this?
CANE CREEK control set 40.Tapered IS42 / 28.6 | IS52 / 40 Tall Cover 1 1/8 "- 1 1/2"
tonytourist
by tonytourist
The lower bearing is 1.25" and you're correct on the IS42 upper.
I swapped mine to the AER II upper bearing and saved some weight. Jason @ Fairwheel should be able to help you.
