Lightest front derailleur? (road 2x)
alcatraz
by alcatraz
Hi WWs
I found that a dura ace 7900 derailleur is 66gr (braze on) so I'm now finding myself looking for one. It struck me though that there might be lighter ones out there. Do you know of any? (without resorting to limited crazy hard to find items)
I don't mind mixing components. I run a sram drive train and only recently found out that front derailleur action is super smooth even when using an ultegra front derailleur with the sram shifters.
I'm currently on 10s.
Thanks for reading
/a
prendrefeu
by prendrefeu
Tiso Altore can be tuned down to ~45g more or less.
Wookski
by Wookski
Old record derailleurs could be tuned to sub 45 as well
Jenmoss
by Jenmoss
The lightest one here is actually 47 graImagems the others are in the 50s
No idea why it’s that light ,the one with the split in the cage.
alcatraz
by alcatraz
Tiso is hard to find, old campy must have a wider cage than necessary for narrow chains.
So is it true that from 9-11 speed fd's, shimano 7900 is probably the lightest?
/a
4ibanez
by 4ibanez
If you want the lightest you might need to be patient. Also depends what shifters you use. Shimano/Sram shifters aren't compatible with Campy FDs (ratios are problematic I've heard). I don't think the width of a Campy 10s FD will be any different to an 11 (using an all Campy setup). There's going to be easily enough adjustment to shift all the way over the big ring.
graeme_f_k
Shop Owner / Manufacturer
by graeme_f_k
4ibanez wrote:
Sun Jan 28, 2018 9:02 pm
Old thread but for reference - Campag 10 and 11s FDs have significantly different width and shape gates.
alcatraz
by alcatraz
I did get a 7900 in the end and it's 66gr spot on.
Tuning is a bit beyond me I'm afraid. I run 10/11s systems so I need that cage width.
Thanks for all the replies.
/a
themidge
by themidge
My 7900 FD is 66 grams too, props to shimano for consistency. It even matches the claimed weight! :thumbup:
Correct me if I'm wrong but I think it's the lightest un-tuned. I know record and tiso etc. can be tuned lighter, but stock..?
