Di2 Manual Shifting Problem
MrMojo
by MrMojo
Just installed 9150 di2 Groupset and can’t get the front mech to shift manually. I’ve tried going through the settings in the iOS e-tube app to disable the synchro shift but no success. All firmware updated to latest. The front mech does work automatically when moving up and down the cassette but I just can’t move it using the shifter. I’ve also tried double clicking the button on junction A to toggle through M - S1 - S2 but again no manual shifting.
Any advice? Probably a simple fix but I just can’t find it!
2017 Colnago C60
2012 Colnago C59
2008 Colnago Extreme C
2005 Colnago C50
2002 Colnago C40 Mapei
2001 Colnago C40
TonyM
by TonyM
Sorry off topic:
An impressive collection of Colnagos! :thumbup:
Which one do you still own?
TonyM
by TonyM
Maybe the Di2 cable to the shifter is not properly inserted?
MrMojo
by MrMojo
I own them all, still!
I unplugged and plugged back in all the cables so I assume they’re all connected ok.
2017 Colnago C60
2012 Colnago C59
2005 Colnago C50
2001 Colnago C40
TonyM
by TonyM
good for you! :thumbup:
Did you run the error check in the e-tube app to?
Can you activate the front derailleur in semi synchro or synchro mode?
Calnago
by Calnago
It clearly needs a Direct Mount Rear Derailleur Hanger.
Oh wait... sorry, wrong thread. Never mind.
Rob1519
by Rob1519
Was the left shifter recognized during the E Tube connection process? Did you check connections at both shifter and junction box? Make sure you use the Shimano cable tool, you should feel/hear the cable seating properly.
TurboKoo
by TurboKoo
Seems to me that you should check button configuration to make sure left side is controlling FD.
Open e-tube and customize
Scott Foil
Shimano 9150
Shimano FCR-9100-P
Shimano C60 tubulars
MrMojo
by MrMojo
Front mech now shifting, I swapped the cable to the shifter from junction A and it now works. Must have been a faulty cable. Thanks for the suggestions.
2017 Colnago C60
2012 Colnago C59
2005 Colnago C50
2001 Colnago C40
