Anyone fitted Specialized Hover bar to their hood road bike?
BiaNeutron
by BiaNeutron
The obvious reason for fitting these bars would be to keep a reasonably low stem but keep the hood height where its comfortable. If anyone has fitted these to a good spec. road bike, wondering on your opinions on how did they look? They are a bit unusual. Is the riser look an outrage?
Mtek
by Mtek
I have the Sworks hover on my BMC. I actually like the way it looks, but cabling isn’t as clean with them. Bike is on my Wahoo, I’ll take a pic or two if you want.
wheelbuilder
by wheelbuilder
Riser road bars look terrible to me.
Lelandjt
by Lelandjt
What is the advantage of this over a stem that angles to put a normal bar in the same place? I just had a rider on my tour with one of these on his Roubaix and we both agreed it looks weird, weirder than a positive rise stem.
BiaNeutron
by BiaNeutron
Thanks everyone for your comments. I agree with all of the points of view. At the moment I'm running with 15mm of spacers and a flipped stem. It's not the best look out there but this is where my bike fitter says I need the bars now. I don't think this warrants looking for a new frame so I'm interested in maybe trying the Hover bar and flipping the stem back round to 'normal'. Just not sure if this would be considered a better look. This is on a Bianchi Sempre Pro by the way. It's not an aero frame and the tubes are fairly chunky so I thought the Hover might look OK.
CrankAddictsRich
by CrankAddictsRich
Lelandjt wrote:
Fri Jan 26, 2018 6:27 am
The advantage of this is that it takes the upward stem angle out of the wind. The hover bar puts the bar where the rider needs it, but keeps the steam angle parallel to the ground and has less frontal area that sees the wind.
2016 Pactimo Brand Ambassador
http://www.Crankaddicts.cc
http://www.skratchlabs.com
2015 Specialized S-Works Allez
2015 Specialized Venge Pro
2014 Specialized S-Works Shiv TT
MayhemSWE
by MayhemSWE
I think the Specialized Hover round bars with 15 mm rise look fine. The Aerofly however not so much as the shape combined with a whole 25 mm rise is just too much.
DJT21
by DJT21
CrankAddictsRich wrote:
Fri Jan 26, 2018 1:27 pm
loolwhut?
They look awful, but what else would you expect from Specialized....
They kinda mark you out as a novice aswell. Better to just spend some time working on your fit so you can run your stem lower.
TLN
by TLN
I was looking at aerofly with 25mm rise because specialized have bigger inner holes: Sram Red Hydro cables exit the shifter in same direction and it's tight fit in normal aerobar. For some reason S made aerofly with rise differently.
Another reason may be: in case you have short steerer tube and don't want to use ugly stem (flipped -12 deg for example). But I'm not sure what looks worse: flipped -12 deg stem or hover bars.
jih
by jih
Just keep the flipped stem. It won't catch the wind even 0,5% as much as your relatively upright body. Worrying about the aerodynamics of stems starts once you're already in an aero bike position.
And who cares if some guys on the internet think a flipped stem and/or this or that bar looks weird? The best part about being an adult is you don't have to care what other people think about stuff that doesn't matter.
dvq
by dvq
I went with the zero rise on my venge vias, the 25mm rise ones just look horrible.
robertbb
by robertbb
I'm running Hover (round) bars with 15 mm rise on two Canyons.
Alloy (specialized) Hover bars on an Ultimate AL SLX
Carbon (s-works) Hove bars on a Ultimate CF SLX
It's personal taste but I actually really, really like the look of them. Kind of like the doors on a delorian or a bird in flight ;-)
I used to have a problem with my knees hitting the bars when I was out of the saddle. These have entirely eliminated that problem without requiring me to stick more spacers under the stem. Stem is now exactly half way up the steerer, with equal spacers either side and IMO it just looks great.
The carbon bars are about 70g lighter than the alloy ones... (I have the exact weights of each at home)
It's ALL about the bike.
by Nefarious86
#antihoverImage
Sent from my SM-N950F using Tapatalk
Using Tapatalk
