Need Help Getting To 12Lbs.
tabl10s
by tabl10s
Had LBS swap Sram Red cranks w/Rotor "Quarbon"(50/34)in favor of Clavicula Classic on the Zero.7 and it went from 6.66 to 6.19kg(14.6-13.65lbs). I now want to hit 12-something. Should I buy the THM Fibula or get a new saddle 100g or below? An employee said I could try the Turbo Cotton's, but I hate the Old School look of the side walls(already lived through that time period). I guess I could also go the eeBrake route
2016 Orbea Orca OMR:
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
2015 Pinarello F8(build in-process).
alcatraz
by alcatraz
Tubulars
angrylegs
by angrylegs
eeBrakes would be good, but as said above, at this point if you're still running clincher and want to go lower, tubulars will make a huge difference.
ancker
by ancker
Tubulars. 1100g seems easy/cheap to find.
Cheap chinese/ebay saddle. 100g
Cheap chinese/ebay bottle cages. 50g
4ibanez
by 4ibanez
Am I missing a build list somewhere? Hard to make recommendations when we don't know about your ride. Cheap Chinese saddle sounds horrible. If you're considering a saddle buy a nice lighter saddle with some flex in it. I'm guessing as you have an RCA you can afford an Ax or Berk?
prendrefeu
by prendrefeu
A current build list and budget limitations would be helpful. Help us help you. ;)
ancker
by ancker
4ibanez wrote:
Thu Jan 25, 2018 11:47 pm
I have one (cheap chinese saddle) on both of my road bikes. As long as you're wearing halfway decent bibs, it's fine.
I'm 68kg and have no problems doing centuries on them and largely forget they're there.
Everyone is different, but they aren't inherently less comfortable than any other minimalist saddle.
Cheap does not necessarily mean 'not nice'. These won't win any beauty contests, but they are very well made and have a reasonable amount of flex.
prendrefeu
by prendrefeu
ancker wrote:
Fri Jan 26, 2018 10:52 pm
Two these two statements: true, then debatable.
They are very well made and have a reasonable amount of flex.
First statement: tendency, yes. 17 "afforable" carbon saddles purchased over a period of 5 years, 2 failed at the joint of rails to saddle.
Second statement: disagree strongly if this is a general statement. It largely depends on which of the non-boutique carbon saddles you are referring to, I've tried 17 of them. Only one had any reasonable flex that can be offered from the likes of Berk or SMUD, and that would be Merek's saddles with their "x-wing" design - but if flex were to be quantitative: the Berk and SMUD would flex at a level of 10 whereas the Merek could flex at a 8, and all others flexed at 1. Merek had to resort to a redesign of their rails in order to achieve a flex that comes close to the Berk or SMUD saddles.
The others are very stiff, and to your point about personal opinion, these were too stiff for my tastes. I do not consider .001mm movement to be flexy.
Since the goal on this site is reduction of mass, and this thread is for an RCA build, let's talk mass:
the majority of Merek x-wing saddles hover over 100g.
The best of the Merek x-wing saddles is their super-short variety (ie, power-saddle style) that comes in under 100g.
The Berk saddles (Lupina) are around 70g.
The SMUD saddle (which is technically my favorite saddle ever, just not being used at the moment) is around 64g.
tabl10s
by tabl10s
The Build List:
Wilier Zero.7-822g(Lg)
https://www.bicycling.com/bikes-gear/pr ... superbikes
Ritchey Superlogic seatpost 176g
http://www.wiggle.com/ritchey-superlogi ... st-1-bolt/
S-Works Power Saddle-160g
http://www.bikeradar.com/us/road/gear/c ... wer-49275/
Zipp SL-70 Aero-240g(first aero bar and loathe to change away from it)
http://www.zipp.com/bars/sl-70-aero/#sm ... 7gtexge9ta
Enve Stem-120g
http://www.wheelbuilder.com/enve-carbon-stem.html
Rotor Uno Cassette-131g
http://rotorbike.com/catalog/default/ro ... sette.html
Qarbon-129g(50t)
THM Clavicula Classic-540.8
http://blog.fairwheelbikes.com/reviews- ... k-testing/
eTap Upgrade Kit-686g
Sram Aerolink-240g
https://www.competitivecyclist.com/sram ... mnEALw_wcB
Roval CLX50-1375g
https://roadcyclinguk.com/gear/reviews/ ... b3ojXog.97
Lizard Skins 2.5-56g
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
alcatraz
by alcatraz
Seatpost/stem/chainring/bars are overweight...
Skewers/inner tubes/tires... usually easy weight loss items. (dont know what you have)
Brakes you could try ciamillo gsl carbon for a few hundred. Saves you nearly 100gr.
/a
KCookie
by KCookie
Really depends on your budget and how far your willing to go.
I would get the EE brakes and one of Jures saddles, that will drop the weight to your intended target. To loose more weight go with the other suggestions and get tubulars with some carbons.
dbnm
by dbnm
Mcfk seatpost is 125g. Mcfk stem is 85g.
Specialized S-Works Arc saddle is 134g
That's a weight savings of 120g over what you have.
What tires are you running now?
tabl10s
by tabl10s
prendrefeu wrote:
Fri Jan 26, 2018 11:12 pm
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
tabl10s
by tabl10s
dbnm wrote:
Sat Jan 27, 2018 6:23 am
The black Turbos. How do you pronounce Mcfk anyway?
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
tabl10s
by tabl10s
Do you have any experience with Gelu saddles?
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
