Cannondale Hollowgram SI SL 1&2 cranksets
alcatraz
by alcatraz
Hi WWs
I'm on bb30 frames (68mm wide shells) for the moment and I'm looking to get one of these cannondale cranks for various reasons I don't wanna bore you with.
My concern is with wide bottom bracket compatibility, should I change frames in the future. The crankset does support multiple axle lengths. It should then theoretically be possible to install on a bbright/bb30a/bb86 frame, should it not?
Will the q-factor be completely screwed up or is it manageable? Has anone attempted to use a cannondale hollowgram on wider bb shells road frames?
How does it feel?
/a
Lelandjt
by Lelandjt
You could get a Raceface or Easton Cinch axle but the chainline and Q-factor will increase by roughly 13mm, maybe 18mm. These cranks are really just for BB30/PF30 frames. Instead buy some BB30 Sram Red (lighter) or Force (interchangable spider & 1x compatible) for cheaper and sell them if you change frames.
AZR3
by AZR3
The Q factor will be really wide, this has been brought up before and when you look at the crank arms of say the BB380evo the arms are spaced differently to the BB30 (SiSL) arms
https://www.bikerumor.com/2011/12/22/fs ... n-weights/
alcatraz
by alcatraz
Seems my only choice is to ignore upgradability or get a bb386 crank with spacers.
Annoying situation..
Thanks for your help! Appreciate it.. /a
alcatraz
by alcatraz
What do you make of this picture? Is this BS or real? Seems light to me considering they are SI and not SISL
/a
