Chainring moon on a stick want!
Monkeyfudger
by Monkeyfudger
Couple of questions, bare with me...
Has anyone ever seen a standard round (non oval) 52tooth aero (mainly because I’m a tart !!) 110 BCD narrow/wide chainring? It doesn’t appear to be a thing!
Fall back chainring will likely be a SRAM X-Sync 52t in 110 but will it fit any 110 BCD crankset or should I expect some weird SRAM silliness meaning it’ll only fit their own crankset, even better, has anyone fitted one to a P2M NG?
Sorry/thanks 8)
kwakekeham
by kwakekeham
Rotor makes the NoQ aero which is a shiftable 5 hole 110BCD chainring.
X-sync is for a 1x drivetrain only but it's style is the same as regular sram rings. However, X-sync is narrow-wide I believe, therefore it is not shiftable because the chain has to fit on it indexed and it has no ramps or pins.
I thought there was an old 52t 110bcd SRAM aero chainring for 10sp, I know I had a 53 aero with 130bcd, but can't find any trace of it. Most of the old SRAM stuff in 10sp seem to be unavailable.
Rudi
by Rudi
Pretty sure these guys will make you whatever you want:
http://www.fibre-lyte.co.uk/fl/fl_cycle ... _2011.html
Cervelo R3 - 5.4kg viewtopic.php?f=10&t=142420
