Gear/Brake cable set for internally cabled S-Works
JBC2
by JBC2
Hi, any recommendations on a complete gear and brake cable kit that has sufficient of everything for an internally cabled Venge?
Bike was build up last year by LBS using a Jagwire kit but I suspect there was not sufficient cables and everything is very tight in the cockpit.
Stripping it all off and installing again but don't want to make same mistake.
Do Shimano do a 6800 kit that has sufficient length for internal routing?
Many thanks
marcelflash
by marcelflash
Just go to a shop who has outercable on a roll.
Innercable Dura-ace polymer is the best for a frame with tight bents like the Venge Vias or with cables going trough the bars.
Be shure to use long nosed end caps from aluminium (Shimano/Jagwire) or the shunts from Specialized.
