Inflating tire on a disc wheel - PITA
alcatraz
by alcatraz
Hi WWs
I was wondering what is the best way to inflate tires on disc wheels?
I've been using a single cylinder foot pump for years without problems.
Now because I am starting to get tired of breaking a sweat before leaving home (I run latex tubes - those who do know what I mean), I've been thinking of running an electrical pump instead or find a better solution for that every day inflation.
The disc wheel requires an adapter that cant be screwed onto the valve. It means if its not completely straight it will leak and your inflation just takes forever or is simply impossible.
So I need to hold the adapter while pumping. Which means bending like crazy or doing it one handed which is a PITA.
I'm now either considering putting a longer hose on the pump or getting an electric one.
What would you do/recommend? Thanks for reading...
/a
mattr
by mattr
Better solution = track pump.
Then they have a long enough hose.
And a decent head for it, it'll seat itself (and not leak).
CarlosFerreiro
by CarlosFerreiro
Common TT bodge to use a cork to wedge the track pump head in place against the inside of the valve hole.
jekyll man
by jekyll man
Official cafe stop tester
mattr
by mattr
That's basically the best "decent head" out there......
Put it on something like a rennkompressor and you'll be laughing.
DurianGrey
by DurianGrey
I'd pick up an air compressor second hand. Sealing issues aren't as big a deal when you have loads of air on hand, and after you've bought a nicer pump and fancy head you're not very far away cost wise. Plus easy tubeless seating.
if you don't want the howling banshee sound of the motor when it kicks on then get one from california air tools, they are very quiet. I have a small horizontal one from them and it can kick on in a basement with the baby sleeping above.
atakaoka
by atakaoka
Remember that most compressor only goes up to 90PSI and fell goes up to 120PSI.
cycling,a great individual sport,were you can't reach anything,whithout group effort.
mattr
by mattr
Mine does 180-200.
But it's a compressor, not a tyre inflator.
