Comparing weights: new generation shimano cranks vs previous
alcatraz
by alcatraz
Hi WWs
I'm trying to find a light and relatively affordable 24mm crank to put on a trek.
Shimano specifies 609gr (50/34) and 621gr (53/39) for the new dura ace 9100 cranks.
I'd like to know if this is accurate. Also does anyone know if any of this 50-60gr weight saving is in the chainrings?
Are 9000 rings compatible with 9100?
Because I'd like to put a power meter on the bike in the future and because double sided meters often require quite heavy crank spider designs I'm looking into a left sided only type.
Whats the lightest 24mm power meter crank out there that is not ridiculously expensive? Seems putting strain gauges on carbon arms is an expensive and complicated process that one should avoid if one wants to save some $$. If no power meter I would get a sram red gxp crank but for power meter I'd have to get a dura ace crank since it's easily available 24mm and hollow alloy which allows for easy strain gauge mounting left side only power meter.
Any thoughts? Thank you for reading...
/a
pdlpsher1
by pdlpsher1
The 9000 and 9100 cranks take any size chainrings. This is done so that the cranks are no longer specific to a certain BCD. So the weight differences between the compact and non-compact cranksets are purely in the rings.
9000 and 9100 rings are not interchangeable. If you have a 9100 crank you must use 9100 rings.
TurboKoo
by TurboKoo
With those specs I’d buy Shimano 9100-P
Scott Foil
Shimano 9150
Shimano FCR-9100-P
Shimano C60 tubulars
Marin
by Marin
With those specs I'd buy a Sram Red with light chainrings and put on a Stages Rival left arm. Actually, that's exactly what I've done ;D
I'm pretty sure this setup will be lighter than a DA setup.
alcatraz
by alcatraz
Good idea Marin
Jhomewood
by Jhomewood
Marin wrote:
Wed Jan 10, 2018 9:15 am
:roll:
Marin
by Marin
