See.Sense Icon Rear Light
mogwaiboi
by mogwaiboi
Hi All
I purchased the above light recently as I wanted something bright with good run times. No problem at all with either of those particular characteristics, but my OCD is running overtime with how much the light seems to move around on the seat post. In my opinion the rubber rear mount isn't grippy enough...not sure if anyone else has one of these and has a similar issue?
https://i0.wp.com/www.titaniumgeek.com/ ... 24x768.jpg
Canyon Ultimate - Ultegra Di2 R8050 - HED Belgium +
Focus Cayo - Ultegra 6800 - DT Swiss PR 1600 Spline
Giant TCX Advanced Pro 2 - 105 5800 - Hunt 4 Season Gravel Disc
2old4this
by 2old4this
I have the Icon+ front and rear. The rear on does not move but the front points down, 15 mins into the rides. I put a small piece a tape between the handlebar and the mount. Seems to help a lot.
BTW, icon+ is really really bright. Can't complain on that :-)
2old4this
by 2old4this
Double post...
mogwaiboi
by mogwaiboi
Thanks 2old4this, what sort of tape did you use?
Yes I ended up getting the + version, it is definitely bright!
Sanjay
by Sanjay
Mine is fine as long as the rubber strap is evenly spaced across the seat post, not pulled to the right or left.
Sent from my SM-G935F using Tapatalk
2old4this
by 2old4this
mogwaiboi wrote: ↑
Tue Jan 09, 2018 10:51 am
Nothing special; some cheap electrical tape. I am sure a cotton tape would do a better job...
