Hugi DT240 freehub body pulls right off?
Catagory6
by Catagory6
everywhere i read, people say to remove the cassette and pull off the freehub body by hand.
or use the cassette for leverage.
i've been working on this thing for the past 1/2 hour and cant get it to budge.
any suggestions?
this hub is from mid 2000s
i've tried inserting a skewer from the NDS and catching an interior lip in the end cap and hammering it out
Catagory6
by Catagory6
persistance beats resistance
dudemanppl
by dudemanppl
Take the NDS cap off, its much easier. Then put an 8mm allen key through the axle and them use a hammer to get the DS end cap out. Or at least thats what I do...
Catagory6
by Catagory6
dudemanppl wrote:
Mon Jan 01, 2018 5:50 am
hammering the skewer from the NDS worked to pop the DS end cap off. and then the freehub body just popped out.
then the spacer between the star ratchets and the axle... holy cow. that was a father mocker to remove. maybe i should have gone over the axle with some 600 grit so the spacer could go on a little easer.
oh boy, the NDS end cap was the bitch of the bunch to remove. once i had the DS all disassembled, i had to hammer the axle to get the NDS out.
not sure if this hub was ever serviced since i bought it in the mid 2000
ms6073
by ms6073
I opted to spend the money on the Park AV-5 hub vise which when mounted in a bench vise, makes end-cap removal a non-event and elminiates the need to bang on expensive or in the OP's case, rare hubs. Also, while probably not a consideration for that generation of hub, when using 12mm or 15mm thru-axle end caps, hammering them out is no longer an option.
Catagory6
by Catagory6
any kind of special grease to re-pack the sealed bearings? i got a tube of ProGold EPX grease, which would seem like a better choice than the much more viscous than the White Lightning Crystal grease
Catagory6
by Catagory6
when your local shop mechanic tells you "... sealed bearings aren't meant to be serviced. they're meant to be replaced... "
:doh:
LeDuke
by LeDuke
Catagory6 wrote:when your local shop mechanic tells you "... sealed bearings aren't meant to be serviced. they're meant to be replaced... "
:doh:
Yeah. I'm at 30,000 miles on the original hubshell bearings on one set of MTB 240s. How? Pull the seals, regrease every 6 months.
Sent from my XT1585 using Tapatalk
kavitator
by kavitator
If bearing is rough it has almost 100% damaged inner races - if you clean and put grease in it i dont think it will go for long time
LeDuke
by LeDuke
kavitator wrote:If bearing is rough it has almost 100% damaged inner races - if you clean and put grease in it i dont think it will go for long time
I think the point is that you can prevent damage in the first place with preventative maintenance.
jlok
by jlok
Preventative maint by re-grease sounds good. What is your best tool to pick out the cartridge bearing seal?
LeDuke
by LeDuke
I've used a razor blade and a very sharp dental pick.
Basically, anything to get under the seal without damaging it.
Catagory6
by Catagory6
LeDuke wrote:
Fri Jan 05, 2018 6:37 am
box cutter, and work it from the inner race. i've found it pries out much easier than trying to get it from the outer race.
and if you bend the seal, you can flatten it out between 2 flat surfaces, and a lot of pressure.
