Need weight advice from Supersix Evo pros - Is something wrong?
alexgodmar
by alexgodmar
Hey guys,
I just built my new 2018 Supersix evo Dura-ace (non-high mod). Without pedals and cages, it weighs almost 7.15 kg. A LBS weighed the same model at 6.8kg out of the box. The exact same bike with Hi-Mod carbon weighs about 6.55 kg. I was expecting something closer to 6.88kg for mine since there's around 300g difference between the two frames. What's going on here? I went through the whole part list and the only different part is the head-tube extender which is 35g lighter and the Arione saddle which is 5g heavier. The next obvious step would be to weigh the frame/fork alone but I don't have access to my workshop right now. Not gonna lie, Iam a bit disapointed. Any input would be much appreciated!
My bike: http://www.cannondale.com/en/Canada/Bik ... =undefined
Hi-Mod version: http://www.cannondale.com/en/USA/Bike/P ... =undefined
My build list:
ImageSSe-Out-of-the-Box by Alex Godbout-Simard, on Flickr
Thanks!
4ibanez
by 4ibanez
40g sounds pretty light for steel cables. 50g for housing could well be underestimated too. Also don't trust claimed weights at all. Saying that, 30g sounds an awful lot for bearing cover and spacer/s. That probably doesn't help much! If you really want to know, I'd suggest you take those estimated parts off and get em on the scale.
alexgodmar
by alexgodmar
4ibanez wrote:
Mon Dec 25, 2017 9:58 pm
Thanks for the input. The weights I stated came from people on the forum and not claimed weight by the manufacturer. It's true that the LBS could have lied about the weight a little bit though. I'll try to take everything a part soon but I will have to wait after the holidays.
Cheers!
hannawald
by hannawald
If you want to go lighter, you can put there some lighter/latex tubes..it is a cheap upgrade and you can save a lot. Find some lighter quick releases and you are almost there..
check the tyres, you can do it easily and they are very often over the claimed weight. My Schwalbe Pro Ones were both 20g over the claimed weight, so it was 40g above expectations..
alexgodmar
by alexgodmar
hannawald wrote:
Mon Dec 25, 2017 10:35 pm
I have many upgrades already in the works but the topic is more about the ''high'' starting point of 7.15 kg. My goal is 6.5 kg with pedals. 80% of the items on the list were put on the scale.
RimClencher
by RimClencher
Have you factored in the weight of expectation?
alexgodmar
by alexgodmar
RimClencher wrote:
Mon Dec 25, 2017 11:20 pm
Have you concidered not being an a** on Christmas day?
bikerjulio
by bikerjulio
I built up a standard 58cm SS in 2011 that's at 15 lb with pedals.
You have a long list of things that could be lighter so it's hard to know where to start.
tires should be 225 ea max
tubes 75 ea.
what are "grips" at 100 g? Not bar tape shurley?
then there's the whole cockpit, the post and saddle
I'm off for dinner now but if I find my list I'll post it
There's sometimes a buggy.
One.
alexgodmar
by alexgodmar
bikerjulio wrote:
Tue Dec 26, 2017 12:09 am
tubes 75 ea.
Thanks! I’d like to take a look for sure. 100g is indeed for bar tape. It was 50g per side on my scale. It’s the one that came with the bike. It’s crazy heavy but the same for every evo.
hannawald
by hannawald
ok, i thought you were calculating the weight of frame and fork subtracting the weight of components from the total weight. And from my experience i can rely on shimano component weight but with tyres there may be bigger excess of weight..
it would be interesting to see your progress, though I am not sure you can get that low with this frameset, clinchers and normal components (not going with exotic parts). But 6,8 kgs should be quite easy..
Hapsmo911
by Hapsmo911
Sorry. Just to clarify. Did you weigh your bike or are you going strictly off your spreadsheet?
alexgodmar
by alexgodmar
hannawald wrote:
Tue Dec 26, 2017 12:33 am
Every component were either weigh by me or by other folks on the forum. The only thing I did not weigh is the frame and the fork. The tires were at 264g on the scale. I forgot to class them as verified. 6.8 kg shouldn’t be too hard to reach as you say, but going to 6.6 will be more expensive. Iam at 7.4 with pedals.
alexgodmar
by alexgodmar
Hapsmo911 wrote:
Tue Dec 26, 2017 12:45 am
I did weigh the bike with my park tool bike scale. Like prety much every component on my list. Only the weight of the frame/fork/cables were estimated.
bikerjulio
by bikerjulio
Here's my SS from 2011. Admittedly with some WW bits, but also includes pedals and standard alloy wheels. 10-speed.
Some of those weights of yours like tape are insanely heavy. There's 3/4 of a pound over in your wheels tires tubes and skewers. OTOH you have 90 g for a cableset? Don't think so.
One.
vejnemojnen
by vejnemojnen
- SRAM Force brake calipers (or even Rival) below 290 grams.
- 23mm Tyres with latex tubes (eg.: Tufo Calibra Light...)
- Some generic chinese bartape (35 grams with end plugs. Costs 1.5-2 USD from ali..)
- Kalloy UNO stem, should come in below 100 grams with titanium screws.
these are the low-cost savings. Later you can opt for a ligther chainset-bb combination, and even seatpost-saddle.
