Etap hydro
markyboy
by markyboy
I have ultegra disc bike but would like to change the brakeset to sram hydro disc etap.
I have the etap front and rear mech and chainset so i dont need the whole lot.
Can i just take off the ultegra shifters and fit it straight to the sram set up?will the hoses fit straight on etc?to save re routing the whole lot.
Colnago master with campagnolo super record 12
Pinarello f8 with campagnolo super record 11
Eddy merckx 69 ultegra disc winter bike ultegra r8000
jlok
by jlok
U need SRAM specific calipers as well.
markyboy
by markyboy
Yes i know but will the hoses just pull off of ultegra and fit onto sram or will i need to reroute the whole lot
jlok
by jlok
U need new SRAM hose. When u buy the etap hrd shifter and caliper set the hose will come together, bled.
markyboy
by markyboy
Ok thanks,but you still need to thread the hose through the frame so will have to disconnect then re connect.
Frankie - B
Administrator
by Frankie - B
In a way, you are asking if a campagnolo derailleur will work on a shimano shifter. The shimano hoses come with a connector that works for shimano style shifters. On top of that, Shimano uses mineral oil and Sram is using Dot. As you might know, the seals for dot, don't like mineral oil and vice versa.
Best is to dismantle that braking system, build it up with the sram parts and then bleed it for best performance.
Good luck! :thumbup:
Please follow me on Instagram
ultimobici
by ultimobici
You’ll need to use the Sram hoses. Sram use Dot fluid and Shimano use mineral oil. The two don’t mix.
markyboy
by markyboy
Ok thanks guys i am new to all this disc stuff.
GonaSovereign
by GonaSovereign
markyboy wrote: ↑
Sun Dec 24, 2017 12:26 pm
Ultegra disc is really good. Shimano brakes work better than SRAM as well. What's driving the switch? Weight?
LeDuke
by LeDuke
This isn't going to work.
Sent from my XT1585 using Tapatalk
markyboy
by markyboy
GonaSovereign wrote: ↑
Mon Dec 25, 2017 1:46 am
markyboy wrote: ↑
I have an etap front and rear mech which i would like to use so thought about getting the etap shifters and brakeset.
I thought i could just swap it out and keep the hoses in place.
VTR1000SP2
by VTR1000SP2
If weight is the main goal, go with 8070 shifters, 9150 derailleurs and it’s a much easier swap.
42.
ergott
by ergott
VTR1000SP2 wrote:If weight is the main goal, go with 8070 shifters, 9150 derailleurs and it’s a much easier swap.
If swapping levers you still have to rebleed system anyway. If there are lines already in the frame, threading new ones is usually very easy.
It comes down to which system the OP wants to use.
Sent from my SM-G950U using Tapatalk
