Pro Stealth Saddle
misterq
by misterq
Anyone switch to this? Wondering how much setback is really needed, feel a bit lost.
https://cyclingtips.com/2017/10/special ... on-review/
Based on this it seems to be less than the Power saddle which seems to be 30mm as a starting point for many.
I had a Antares but after a fit that really helped me a ton recently, the antares wasnt as comfy as once was.
Any advice?
I now have the Stealth about 15mm back and 4-5mm higher
TobinHatesYou
by TobinHatesYou
Setback is dependent on where the flare of the saddle is and how much pelvic rotation you have.
The Specialized Power is 240mm long, the Pro Stealth is 255mm long, but with more hanging off the back. I imagine the amount of setback should be similar, and approximately 3.5cm farther back than that of an Antares (nose to BB)
stoney
by stoney
I love my Pro Stealth Saddle. I have one on my MTB and my CX/Gravel bike.
misterq
by misterq
stoney wrote:
Tue Dec 19, 2017 12:18 pm
what saddle you change from, did you have to slide it back a bit or any other mods?
CallumRD1
by CallumRD1
I rode a Power saddle for a few months before switching to the Stealth. I just placed them next to each other on the table, matching the point where they flare out. I then translated the camp marks from the Power saddle rails over to the Stealth saddle so the setback should be comparable. This made it easy to match position. As far as height, I just remeasured from the bottom bracket to confirm my 81.5 cm saddle height. I don't remember how much I had to adjust the height to compensate for the saddle change. Several thousand miles later and I am loving the Pro Stealth. The wider nose made it far more comfortable for me and gave me a few slightly different positions on the saddle. Far better than the Power for me.
stoney
by stoney
misterq wrote:
Wed Dec 20, 2017 6:34 pm
I had a Specialized Power on my MTB but it cracked. The Pro Stealth looked a little more robust so I thought I'd try it. For all my saddles I use a plumb bob from my knee to my pedal spindle to set the fore/aft position. And of course the nose will be further back from the bars than a "normal", longer saddle.
misterq
by misterq
TobinHatesYou wrote:
Mon Dec 18, 2017 11:45 pm
Can you elaborate on the pelvic rotation since I feel saddle is in right place compared to old fizik but feel PR is much better but something is off.
dbnm
by dbnm
I pondered both the S-Works Power and the Stealth. The Stealth is heavier but costs less.
So I bought the Specialized S-Works Arc. :)
wheelsONfire
by wheelsONfire
Off topic, but...
You should add ISM PN 3.0 to the list. I prefer this over Pro Aerofuel which i prefer over Stealth
Bikes:
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
misterq
by misterq
couldnt get the setback I needed so selling the Stealth 142 carbon if anyone wants one. 105 shipped!
wheelsONfire
by wheelsONfire
Do you have a setback seatpost? If yes, don't you have possibility to use another seatpost with more setback?
I have more setback with ISM PN 3.0 than with Pro Aerofuel.
Not sure, but since Stealth have a tail up design, perhaps you'd need less setback with Aerofuel and/ or PN 3.0
I would recommend ISM PN 3.0. For me, a better saddle. But you'd lower the seatpost changing from Pro to ISM.
I didn't experience any inner leg chafing with PN 3.0 compared to PL 1.0.
Also, PN 3.0 feels much better if you'd like to move more rearwards when in dropzone.
It also feels flatter in a good way.
Bikes:
Ex bike; Vial EVO D
spud
by spud
misterq wrote:
Sat Jan 20, 2018 7:13 pm
check for PM
misterq
by misterq
stealth sold fast thnx guys
by Nefarious86
wheelsONfire wrote:Off topic, but...
Are you able to measure the distance from the nose of the Aerofuel to the bend in the rails by any chance. I need to run the saddle slammed back on my DA1 to fit into the UCI regs.
Sent from my SM-N950F using Tapatalk
Using Tapatalk
leandrofresh
by leandrofresh
misterq wrote:
Fri Jan 19, 2018 5:57 pm
Im not sure if he's talking about how much forward you can bend from the pelvis or about hip rotation. Nonetheless, the more unstable your pelvis is, and the less you can rotate your pelvis forward, less setback.
