Thru axle adapter
markyboy
by markyboy
I need the tacx neo thru axle adapter,not sure what size i need :noidea:
My bike is this one
http://www.wiggle.co.uk/eddy-merckx-mou ... 5510473408
Thanks in advance
COLNAGO C60 SUPER RECORD EPS
Pinarello f8 sram etap
Eddy merckx 69 ultegra disc winter bike
ms6073
by ms6073
You need a Tacx T2835 Direct Drive 142x120mm Quick Release with Adapter Set.
markyboy
by markyboy
Ok thanks just wondered as i saw some 135x10
jfranci3
by jfranci3
Looks like Stance 12mm or 10mm
Unclear but it says "Axles" http://www.wiggle.co.uk/eddy-merckx-mou ... disc-2017/
and 135x10mm here.
https://www.merlincycles.com/eddy-merck ... 01899.html
Time for this: http://amzn.to/2BXOJI1
markyboy
by markyboy
Just spoke to wiggle and they say,
This has a bolt thru rear axle of 135x10
ms6073
by ms6073
markyboy wrote:Just spoke to wiggle and they say, this has a bolt thru rear axle of 135x10
Strange that the product description indicates 12 mm front thru-axle. So if it is 135x10, you do not need a thru-axle adapter, and the Neo should include a spacer to adapt for a 135mm rear end.
Tacx neo Additional Instructions
markyboy
by markyboy
Cheers i will check the box,also i have bought an adapter but can always send it back.
If its wrong fitment i will try the other size
ms6073
by ms6073
Sorry, complete lack of reading comprehension, as I was confusing this with something like DTSwiss 10mm thru bolt. You will need the Tacx T2840 135x10 adapter
