Madone Disc Spotted
TobinHatesYou
by TobinHatesYou
What kind of QR skewers are you using on these bikes, if I may ask?
TonyM
by TonyM
Looking at the new Madone and seeing that green colour reminds me the Celeste colour of Bianchi :shock: :shock:
jlok
by jlok
This is probably part of the CMYK series by a lazy designer...
TonyM
by TonyM
I actually like this colour :thumbup: but I couldn't imagine having a bike in this color if it is not a Bianchi :|
(Because of that color I suppose that I may one day get a Bianchi myself actually)
If a Madone for me either black or red.
Tango
by Tango
In 2013 the race bikes by Trek already had this colour. It look so wrong for me, but still like those unconventional colour styles.
Stitchking
by Stitchking
Mirco wrote:
My saddle height is 81cm. Concerning the Venge Vias Disc Geo, I am riding a 56 frame (stack 564mm) and 25mm Spacer. So an 56 Madone frame nearly has the same Geo and including the headset top cap I assume 10—15mm Spacer should work. The problem is the given max. saddlerail height of 76cm of the 56 Madone frame.
Ok, saddlerail height and saddle height depands on the saddle itself. I am riding Specialized Toupe Pro saddle which might be more flat than the bontrager.
As I mentioned above, saddle height is 81cm and saddlerail height with an Specialized Toupe Pro is 77cm.
regards
Mirco
If your saddle height is 81cm you probably should be on a 58cm frame. Mine is 78.5 and im having to buy the longer seatpost as the standard one only goes up to 76.5.
Are you running the weird riser bars on the venge? Theyre probably the difference in headtube length between the 56 and the 58
Sent from my SM-G935F using Tapatalk
Mirco
by Mirco
Stitchking wrote:
Sat Jul 21, 2018 11:25 am
regards
Mirco
No, I am running the Vision Metron 5d on my Venge Vias Disc.
I am also waiting for some build up of the new Madone Disc in size 56 and of course size 58 to get an idea how it looks like. I am not in a hurry, because the road season lasts until mid of september, then cyclocross race season starts and training is a bit different.
Slack
by Slack
jlok wrote:
Sat Jul 21, 2018 6:51 am
This is probably a lazy comment by some one on a forum.
This colour has been part of Trek's range for a few years. It's the bike of the Trek Drops cycling team.
https://www.trekdrops.com/
jlok
by jlok
So the designer of that team was lazy lol
hlvd
by hlvd
jlok wrote:
Sat Jul 21, 2018 3:00 pm
I doubt they're the exact same colour though.
A few years back the Trek team had a similar colour, can't remember it properly but it was really nice.
jlok
by jlok
chill, just kidding. Madone got the best paints this year no doubt.
TobinHatesYou
by TobinHatesYou
Celeste has been many hues over the years. It’s even a different hue on the Specialissima vs the Oltre XR4.
wheelbuilder
by wheelbuilder
I have been messing with this at my leisure over the last week and it is coming together. However the measurements that Trek provides for housing length prior to running through bar/stem are about 60mm too long. Not a huge deal to trim but a bit disappointing. Mechanical shifting on this bike is a bad idea. Shouldn't even be an option. Image
Sent from my BBB100-1 using Tapatalk
Calnago
by Calnago
@Wheelbuilder: is the new Madone that much different to set up than last years model. I have one sitting in front of me deciding if I even want to deal with it. At first I agreed to the build providing we could do Campy 12 mechanical. But in good conscience, I can’t recommend mechanical for any of these frames where acute internal bends are required. So I suppose it will be Di2.
