Rim tape for tubed/tubeless with latex/butyl
Marin
by Marin
DON'T use cloth rim tape in tubeless ready rims. It will make tire installation hard to impossible.
Proper tubeless/strapping tape is lighter, tougher, thinner, airtight and flexible, and I actually can't think of any disadvantages.
mpulsiv
by mpulsiv
Marin wrote:DON'T use cloth rim tape in tubeless ready rims. It will make tire installation hard to impossible.
Will I need to install two layers of tubeless tape? Is this a standard procedure with what I call double wrap?
Per quote from Boyd tubeless kit "The tubeless kit above will include our new (blue) tubeless tape http://www.boydcycling.com/shop/accesso ... eless-tape and tubeless valves http://www.boydcycling.com/shop/accesso ... ess-valves pre-installed on the wheels! We will install two layers of the tubeless tape in the exact width you need for your wheels.
TobinHatesYou
by TobinHatesYou
Yes, I would always use 2 layers of tubeless rim tape for road pressures. It’s like 5 extra grams for two wheels.
mpulsiv
by mpulsiv
TobinHatesYou wrote:Yes, I would always use 2 layers of tubeless rim tape for road pressures. It’s like 5 extra grams for two wheels.
Ah, now I understand why tubeless rim tape is thinner for 2 layers in contrast to standard (e.g. for tubed application).
dvq
by dvq
I just use Tesa 4289 tape in a large roll I got on EBay
https://www.ebay.com/itm/Tesa-Tape-4289 ... 1623545901
Same as Stans tape, stretches well, 2 layers per wheel means enough tape for 16 wheels.
Marin
by Marin
I use 4289 too.
Orlok
by Orlok
If you use Schwalbe tubeless tape you can wrap only one layer.!
viewtopic.php?p=1365030#p1365030
Once comes a time that you'll have a tailwind :D
Pinarello F10 - Ultegra 6800 - Carbonspeed C38 - Tubeless
Marin
by Marin
Why?
Orlok
by Orlok
Because Schwalbe say so;
Because I do/did;
Because it works so.!
Marin
by Marin
You said "can" - I want to know what the limitation is. Tape too thick? Too short? Forbidden in the manual?
peted76
by peted76
For the past 18months, I've been running one layer on my front wheel of the thin goldy looking 3M made tape which is probably the same as other tapes which is not made by but sold by bike brands.. mine was from a Giant tubeless kit.
I weight 76kg's btw, so no flyweight.
Marin
by Marin
I've been running a single layer of Tesa as well, but with narrower tires / higher pressures, it does sink into the valve holes a little, so I started using 2 layers. The weight difference has to be minimal.
Orlok
by Orlok
Marin wrote:I've been running a single layer of Tesa as well, but with narrower tires / higher pressures, it does sink into the valve holes a little, so I started using 2 layers. The weight difference has to be minimal.
Two layers Tesa will sink a little into the valve holes too but will hold the high pressure of 100 psi.! :wink:
bm0p700f
by bm0p700f
stans tape is a bit paler than the tesa 4289 tape so it may not be the same but it seems to be the same thickness as stans. Tesa in the u.k also dont know about stans which tell me stans is not tesa.
