Pinarello F10 with EPS V3
Bridgeman
by Bridgeman
I have pretty much everything I need for the build. Record EPS V3 and F10 frame. I am wondering if there is anything I should be aware of. Anyone who has done a similar build, did you encounter any problems?
Also, did you need to face the bottom Bracket?
XCProMD
by XCProMD
I know of four different F10’ with EPS V3 ranging from Chorus to SR.
No special requirements or cautions and all is going smooth. No need to face the BB.
Inviato dal mio iPhone utilizzando Tapatalk
TonyM
by TonyM
Bridgeman wrote:I have pretty much everything I need for the build. Record EPS V3 and F10 frame. I am wondering if there is anything I should be aware of. Anyone who has done a similar build, did you encounter any problems?
Which powermeter will you use ?
Bridgeman
by Bridgeman
XCProMD, Thanks, that's reassuring!
TonyM, Haven't considered a powermeter, though I've been curious from time to time.
TonyM
by TonyM
If you want a powermeter I can really recommend you the P2M. I am quite happy with it on my SR.
