Shimano DA 9000 vs 9100 crankset
Grimpeur
by Grimpeur
Can't seem to find a good comparison online, are there any major differences aside from the color and the 9100 being a bit narrower?
Cheers
This is my Bike. There are many like it, but this one is mine. Without me, my bike is useless. Without my bike, I am useless.
Daniel1975
by Daniel1975
Probably no much difference. But 9100 is less ugly, major point ;-)
stormur
by stormur
Personally I like look of the 9000 more, but "beauty" it's veery disputable.
From what I've seen 9100 is much more prone to scratching. Over time it maybe be issue.
Mark Twain
Conza
by Conza
stormur wrote:From what I've seen 9100 is much more prone to scratching. Over time it maybe be issue.
Can confirm this. :?
It's all about the adventure :o .
tguillaume
by tguillaume
I have both on my bikes...
They work perfect !
The difference is between the chainrings, on the 9100 the space is 0,4mm more than on the 9000 !
Grimpeur
by Grimpeur
Tnx for the info guys.
Will go with 9000 cranks then, as they were much cheaper, and imo nicer looking too.
PinaF8
by PinaF8
Grimpeur wrote:Tnx for the info guys.
Honestly I too prefer the 9000 cranks and it goes well with the dura ace srm power meter. Only dislike about it that the color looks like an ultegra to me.
S-WORKS VENGE 1ST GEN
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
ms6073
by ms6073
tguillaume wrote:The difference is between the chainrings, on the 9100 the space is 0,4mm more than on the 9000 !
Not to mention that the shape of the mounting lug closest to the crank arm is curved slightly, which for now at least, limits choice of aftermarket rings such as Absolute Black.
LiquidCooled
by LiquidCooled
Also, Shimano says you can use the new front mech with the old crankset, but not the old front mech with the new crankset. There is anecdotal evidence on the web where folks are using the old FD with the new crankset just fine, though.
2017 Giant TCR Advanced Pro 0 Disc
2003 Cannondale R1000 (CAAD7)
Philbar72
by Philbar72
I've got 9000 front mech on one bike and 9100 on the other. both work fine with a couple of tweaks.
sun
by sun
Has anyone found a way to put 9100 rings onto a 9000 crankset? I have a Quarq Dfour that I migrated to a 9150 bike.
XCProMD
by XCProMD
On a pure theoretical note: the new version has a higher effective moment of inertia than the old one due to the larger cross section of the crank arm and the fact that the part under the centroid has thicker walls than those above it.
Inviato dal mio iPhone utilizzando Tapatalk
OHYONGUN
by OHYONGUN
I know that the 9100 is a little more stiffer. The color 9100 is good.
Aya
by Aya
I prefer 9000 because I like its shiny silver color!!!
Broady
by Broady
ms6073 wrote: ↑
Sun Dec 10, 2017 8:22 pm
Don't suppose you could elaborate on this? I've just ordered a 9100 chainset and was hoping to put my 9000 Absolute Black Inner ring on.
