Will R8070 levers be compatible with 6870 FD and RD?
(The answer may be buried in the huge Ultegra thread, but I can't find it, if it is there. Sorry and thanks.)
2015 Specialized Crux Pro
2013 BMC TMR01 custom build
2013 Cannondale F-Series 29'er, Carbon 3
2012 Cannondale CAAD10-1 custom build, 14.06 lbs
1980 Palo Alto custom build
Short answer: yes.
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
FIJIGabe wrote:Short answer: yes.
Longer short answer - up until Shimano pushes a firmware update that prevents cross-compatibility, as was the case after the introduction of the 9070 series.
- Michael
ms6073 wrote:Longer short answer - up until Shimano pushes a firmware update that prevents cross-compatibility, as was the case after the introduction of the 9070 series.
Ehh, what? The only combination I can remember used to work until Shimano actively blocked it were a 10-speed 6770 front derailleur with an 11-speed rear derailleur. Has there been anything else?
ms6073 wrote:FIJIGabe wrote:Short answer: yes.
As far as I recall, all of the 11sp DI2 components have always been cross compatible with each other. I do recall Shimano using a firmware update to remove the ability of the 10sp 6770 Ultegra DI2 levers to shift the 11sp RDs and FDs.
Shimano requires that the FD and RD be designed for the same number of cogs. So, either both 11 speed or both 10 speed. That prevents a cheapo 11 speed upgrade by only changing the RD. It actually initially worked (I had it) and then they changed the firmware and it stopped working. The levers don't matter. Any lever will work with any derailleur.
