Increasing Drop
ms6073
by ms6073
rossjm11 wrote:Would a better solution be pulling my stem back a centimeter If I did want a bigger drop?
Are you seeking performance improvements or trying to look more 'pro'? I have seen triathletes and time trial specialists go gonzo for getting lower on the front only to see overall performance suffer because the athletes could not comfortably maintain the position for the duration of an event. Seems to me you need to spend some time on a Smart Trainer with a training app that you can use to definitively quantify the results of these changes to make sure you are actually making improvements.
ergott
by ergott
There is a point that you can't get your leg up and over crank without sapping power from opposite leg. I agree, straight back and rotate hips first (if you don't have any physical limitations).
Sent from my SM-G950U using Tapatalk
