Pairing Record EPS V3 with iPhone and MyCampy app
david75
by david75
I just got a new Bike with Record EPS v3. I downloaded the MyCampy app on my iPhone 6s plus. The MyCampy app recognizes the v3 and asks for the numerical code on the interface unit. When I type in the code their is a pause of a few seconds then the screen goes back to the MyCampy app home screen and does not pair. Also if I go to my iPhone settings and then to bluetooth, the iPhone does not recognize the v3, ie the iPhone does not show the v3 as discoverable. If anyone has thoughts on this I would greatly appreciate hearing them. Thanks
Disc0
by Disc0
Are you sure you're using the right code?
IIRC, there are two sets of numbers in different places on the v3 interface and only one works as the pairing code.
Disc0
by Disc0
You're looking for a 6 digit code, though there may be leading zeros shown on the interface.
I think the video here got me through pairing with iPhone 7:
https://mycampy.campagnolo.com/en-US/faq
david75
by david75
Thank you for your responses. On the interface on my bike there are numbers in two different places but they are the same set of numbers. When I enter the 6 digits the app and interface don't pair.
Disc0
by Disc0
Once the app accepts the pairing code, you should be getting a solid blue screen with a slow-moving blue progress bar.
If it's sending you back to the home page, I'd guess the app isn't accepting the code for some reason.
I'd be sure the v3 battery has a full charge and the phone and EPS unit are close together to rule out transmitter/reciever power issues.
Then, there's a set of connection troubleshooting steps in the second video at the link I posted above.
david75
by david75
Thanks again for your response. I have tried all the troubleshooting steps but still unable to pair. My iPhone does not seem to recognize the v3. I hold my phone right next to the v3 interface when trying to pair. Very frustrating.
Disc0
by Disc0
If you got to the point where the app asks for the pairing code, the phone has to be recognizing the v3.
You may have tried these, but just in case:
- delete the app, turn off the phone, reinstall the app
- turn off the v3 with the magnetized rubber strap (verify it's off by pressing a shifter mode button and being sure the interface green light doesn't come on)
- wait a bit, take off the strap, turn v3 back on with a mode button and try again to pair from the app
RichTheRoadie
Tinker, Taylor, Tart
by RichTheRoadie
You're using the wrong code.
There are a number of codes on the interface - have a look at them, write them all down and try them all systematically. When it accepts the right code it won't spit you back out to the home page.
Mockenrue
by Mockenrue
It's this one:
david75
by david75
Found the right pairing number and it works. Thank y'all so much for your help.
