What bottom bracket works for a QUARQ DFOUR91 on Cannondale SuperSix Evo 2015?
kode54
by kode54
need a little help here. a friend is putting a QUARQ DFOUR91 with Dura Ace rings on his 2015 Cannondale SuperSix Evo.
i pulled the previous BB out...and it was one for a Shimano 24mm spindle. the BB housing won't take a new bearing since i pressed them out and measured the ID. its 37mm. the 30mm bearing is a 42MM O.D.
so it looks like i need to get a new BB housing for him. any suggestions? much appreciated.
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 7.8 carbon hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 4.5AR CK CL hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
wingguy
by wingguy
GXP or BB30?
AZR3
by AZR3
Edit-listen to jwfinesse, clearly I didn’t do my research :oops:
jwfinesse
by jwfinesse
All Quarqs are either BB30 or GXP. It may use Shimano chain rings but the crank system is that of Sram’s. So among all of the current Quarqs, nothing is compatible with the above wheels mfg bb. You need either a pf30 (if it’s evo hi-mod) or GXP bb from the same company.
kode54
by kode54
Thx.
savechief
by savechief
If the Quarq DFour is the GXP version, you could try the Praxis Works conversion bottom bracket.
https://praxiscycles.com/product/conv-b ... xp-isis-2/
Time VXRS Ulteam (7.16 kg)
viewtopic.php?f=10&t=120268
