S-Works 7 road shoes?
BianchiDave
by BianchiDave
Visus wrote:
Mon Jun 01, 2020 11:38 am
On one of my shoes the Boa dials are a bit loose so the make a climping noise while walking. Feels a bit like you're wearing those cowboy boots :lol: On the other one no such thing.
Does anybody have a solution for this (besides exchanging the Boas)?
I love my SW7 shoes but my right one has started making this same noise from the lower boa. Annoying, but don't hear it when I'm on the bike. What I do hear, again from right shoe only is a weird creaky click sound when putting more power down. If just light spinning there is zero noise. Tried just about everything, small bit of lube at cleat pdal interface, carbon paste between cleat (time iclic) and sole, greased cleat bolt threads and ensured theyre torqued correctly, sprayed silicone in and around the cleat bolt holes and put vaseline on the upper at the interfaces of the tongue! Noise is still blood there!! I do wonder if it could be the same noisy boa....
Its definitely not coming from the pedal as the shoe does this on both my bikes and I've ruled out pedal threads being a cause. I like a nice quiet bike and this is driving me nuts! Anyone have any other suggestion?
kode54
by kode54
justonwo wrote:
ryanw wrote:
Sat Jun 27, 2020 5:43 pm
I have 7s and Vents.
Had the 7s since launch and like them (now my turbo shoes), and got the Vents a week ago.
Vents performing lovely in the heat and very stiff (can't tell the difference).
Wore on a wet ride yesterday and the fabric / cotton material has stained so they look grubby already.
The material also bunches a bit on the outside (above little toe / side of foot area.
I asked Specialized about the fit of the Vents and they emailed that the fit of the Vents and 7 is the same. Is that true? They also said the Vents should really be treated as "race day" shoes and that the uppers are much more fragile than the 7. Interesting . . .
I have a pair of Vents and used on hot days. Didn’t know they were race day shoes LOL. I’m replacing a pair of regular S-Works 7. The fit is the same but the shoe overall is more comfy. Different material used around the ankle and heel cup areas. Perforated insoles. Seems lighter. The outer material is similar to the more expensive EXOS but with mesh vents.
- Factor 02 VAM Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Factor LS Disc + DA9170 + Enve G23 CK CL hubs
- Repurposed Guru Praemio R w 3D disc dropouts + DA9170 + Enve G23 CK CL hubs
bosco2814
by bosco2814
Delete
S-works 6, there are some cutting line
S-works 7, it is not same as s-works 6
It can be 180 rotated to get 5mm rewards
bosco2814
by bosco2814
bosco2814 wrote:
Sun Jun 28, 2020 2:17 am
I just bought a pair of s-works 7 to replace my s-works 6.
However, I have no idea how to rotate the t-nuts on the s-works 7, the inside is no same as s-works 6. I did that on my s-works 6 to get the 5mm rewards.
Here are the pictures of the inside of s-works 6 and 7.
Ronin416
by Ronin416
g32ecs wrote:
icantaffordcycling wrote:
Tue Jun 02, 2020 3:01 am
Black shoes just sell the best. Don't the current model SW7 come in wide in white?
Hell would freeze. The bike industry will die if they made some WIDE WHITE SHOES I swear.
There’s always Bont Vaypor-S, wide and double wide available.
Ronin416
by Ronin416
g32ecs wrote:
Unniti wrote:
Tue Jun 02, 2020 8:03 am
g32ecs wrote:
Tue Jun 02, 2020 2:55 am
Hows the fit if the regular width?
I have wide feet but I hate BLACK SHOES. I dont know what's with Shimano Lake and Specialized thinking people with Wide feet LOVE BLACK SHOES (?)
Hoping the regular width has a roomy toe box and just stretches overtime. There's a deal Im closely watching right now Im losing sleep over it.
g32ecs wrote:
Tue Jun 02, 2020 4:01 am
Bont?
Avoiding Bonts. They're amazing for crits, but godamnit my feet were crying after. They're ultra stiff, it's some BDSM masochist shit I swear.
Im gonna end my rant here Image. Woosah.
Try a cycling specific insole in your shoe if you don’t have one at the moment. That may help.
Ronin416
by Ronin416
It’s next to impossible to dislodge the excess glue holding the nuts inside the sole. Even pushing super hard with the cleat a little loose doesn’t help much.
Fix - I used an Allen key and pressed down slightly, don’t over do it and push right through the inside of your sole. That will help break the glue fixing the nut in place and provide you the adjust to slam the cleats back. See my posted story @smoothpedlar “S-Works 7 Fix”
I just did these on my Vents. Not too impressed with the shoe. Looser fit up top due to the mesh, don’t really feel the air coming through But they look cool!
bosco2814
by bosco2814
Thanks for the reply.
My LBS told me to use a medical scalpel to make a cut line, though I used a utility knife to cut it.
And yes, I used a Allen key to push from the outside to break the glue. It took me for a long time.
S-works 6 is a lot easier. Specialized should copy Shimano rc901 nuts design.
CustomMetal
by CustomMetal
Any news on sworks 8?
Perdita- Burls Ti - 8kg
Aurelia- Saffron Stainless/Carbon - 9kg
Bertha - Trek Speedconcept
Verity - Sturdy Ti/Carbon Aero (incoming)
Serenity- Sturdy Ti (incoming)
Allegra - Sturdy Steel Lugged (incoming)
Jolene - Aluminium Crit Bike (being reborn)
MRM
by MRM
I wouldn't expect it in 2020.
icantaffordcycling
by icantaffordcycling
ajcav86 wrote:
Mon Jun 29, 2020 8:12 pm
Mid 2021. Specialized does 3 years for shoes.
Expect some cool stuff with exos soon though.
allenpg
by allenpg
I was looking at the getting the S-Works 7 and was told by my shop to wait because the 8 was going to be out really soon.
kode54
by kode54
Nothing wrong with the 7.
CustomMetal
by CustomMetal
kode54 wrote:
Mon Jun 29, 2020 8:34 pm
I'm sure not but will kick myself if a new one comes out the next week 🤦‍♂️
CustomMetal
by CustomMetal
I also have a set of recons (sworks) and find where the Velcro strap is is a bit too much material.. I have narrow feet
