Campagnolo Bora freehub grease
wedgie
by wedgie
I'm replacing the outboard bearing on my Campagnolo Bora One freehub. Campagnolo recommend their own LB-100 grease to lubricate the pawls and ratchet teeth when reassembling, but I can't find it anywhere. Any recommendations for an alternative grease?
bikerjulio
by bikerjulio
It should be low viscosity, not sticky. I use lithium grease. It's easy to check the pawl action before you reassemble.
There's sometimes a buggy.
One.
TonyM
by TonyM
I had the same problem as I couldn't get the LB-100 in USA/ Canada.
I saw however that Campagnolo North America recommends the Dumonde Tech PRO X Freehub Grease as an alternative to their lb-100 Grease as it is no longer available in North America.
https://www.dumondetech.com/portfolio/p ... ub-grease/
I bought mine here:
https://shop.mylifeatspeed.com/product- ... ubricants/
But here some other options:
https://www.dumondetech.com/online-deal ... 34a7f-ed06
Hope it helps!
Mackers
by Mackers
Campy grease is just rebranded Kluber Isoflex Nb52.
