Ti seatpost in a Ti frame?
taztaylortaz
by taztaylortaz
so... what is the consensus on using a Ti seatpost in a Ti frame? In this case, it's a Record Ti (vs Record Carbon) in a Serotta Legend. No aluminum or other sleeve in the seat tube so it will be a Ti/Ti fit.
I've read that there's no galvanic corrosion but there can be galling. Some say use Anti-seize, others say regular grease or copper paste(?).
I'm mostly set and forget once I have my position and since I have several bikes, the maintenance intervals can be several years for a non moving part like seat post or h-bars.
Also, is there an issue with using Ti water bottle bolts in this frame (Ti welding)?
AJS914
by AJS914
If you are using grease or anti-seize and not riding in the rain I doubt you will have any problems. I owned a Litespeed for 20 years and never had a problem with aluminum seatposts. I always greased them with some thick all-purpose synthetic lithium grease from the auto parts store. To be safe I'd re-grease it once a year if you ride in the rain.
Aren't Record Ti seatposts clear coated?
sungod
by sungod
i'd use antiseize on threads
on the post, assembly paste to reduce clamping torque
TonyM
by TonyM
I have a campy Ti seatpost in my aluminum frame (with lot of grease before the winter) and after the last winter and lot of rain it has seized!
