Wahoo Element Bolt - negative display field?
Shrike
by Shrike
The promotional image for the Elemnt Bolt shows a negative display speed field.
Can you actually do that on the Bolt? Looking at real life videos I don't see anyone doing it. Thinking about switching from Garmin and researching features..
youngs_modulus
by youngs_modulus
The negative display field indicates which field is tied to the LED strip at the top. To get the speed displayed as a negative, you’d need to tie it to the LEDs. That means the LEDs light up more as you go faster.
Because no one needs the LEDs to tell them when they’re going relatively fast, they’re redundant if you tie them to the speed field. No one does that, which is why you don’t see the negative speed field in videos.
Shrike
by Shrike
So if you had the LEDs tied to watts, the watts field would turn negative?
That'd be class :P
glepore
by glepore
No, I have my led's set to power and it doesn't. The leds display zones, not actual watts. I guess if you had a field set up for zones it might invert. Speed and hr do invert when selected for leds.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
stevec1975
by stevec1975
I have my bolt set up like that, the LED lights link to if I am up or down on the Avg speed. It's fairly useful.
Leviathan
by Leviathan
So how do I get the LEDs to light up in sequence left to right and back? Like this:
https://www.youtube.com/watch?v=WxE2xWZNfOc
Shrike
by Shrike
Oh, bit of a shame. Hope they add it later in an update. Do Wahoo update their products with new features like Garmin does quite regularly?
jfranci3
by jfranci3
That negative field, I believe, is the Speed vs Avg or Speed vs Lap, not speed.
stevod
by stevod
Shrike wrote:Oh, bit of a shame. Hope they add it later in an update. Do Wahoo update their products with new features like Garmin does quite regularly?
Yes!
https://support.wahoofitness.com/hc/en- ... re-Updates
Shrike
by Shrike
jfranci3 wrote:That negative field, I believe, is the Speed vs Avg or Speed vs Lap, not speed.
Ah that's quite clever. So you can see your speed and average speed and get a kick up the backside all in the same field :lol:
Yes!
Like it! Only been out since March and they're putting in solid updates. Gonna pick one up and hope they let us have a watts negative field in future 8)
Buhbyee Garmin :P
Shrike
by Shrike
DBL post :shock:
Jensa
by Jensa
I would say they updates more with new function then garmin does. atleast thats my experience after owning a garmin device and now a elemnt bolt. With garmin it was as you were a paying beta tester, they send out a fix to a bug and give you two new ones. I was bored of that the best thing i could do when garmin let out a new software, was waiting a week, and then go to garmin forum to see if anyone had a problem with the new software before i update. haven't had anything like that with wahoo. And bigger updates to the wahoo, with for example the new live tracking.
stevod
by stevod
^Agree. I moved from Edge 500 to 520 to the Bolt.
Shrike I don't think you'll be disappointed.
saba
by saba
Single session on a wahoo = sworn off Garmin until they fundamentally change their approach.
Shrike
by Shrike
Sounds like you guys are getting on well with yours. Mine's arriving tomorrow. Some good news for you! 8)
Hi xxxx,
Thank you for your inquiry. The data field associated with the power LEDs is going to be 3s AVG Power.
However, we do have a current firmware bug that is causing that power field to not invert correctly.
Our developers are aware of this issue and are actively working on a fix for it.
Please let me know if you have any questions.
Thanks,
xxxxxxx
