Clip-On Aero Bars for Stem
addictR1
by addictR1
mrtkcmz wrote:
addictR1 wrote:hi OP.. i have the same Zipp SL 70 aero bars. there's not much space available for aero clip on. you could use something like this.
https://goo.gl/U4i9QZ
Origin8 Mini Clip-On Tri Bars, 25.4 - 31.8
granted the bar is pretty short.. but perhaps can be replaced by other bars from other brands or use PVC pipe to reduce weight. i've thought about it but never went through with it. don't do enough tri to do get this for my TMR02
good luck
I saw it before. +1 have you ever try it on SL 70 Aero? can you fit the clamps?
There's been others that have tested and work on the SL70.
addictR1
by addictR1
good luck
